loom swop
Dubcrazy
loom swop
Post by Dubcrazy » Tue Nov 25, 2008 5:50 am
Is it possible to swop the wiring loom on my EA82T three plug(to ECU) to a four? Its only the wiring from engine to ecu, nothing else as the engines in my *coughvwcough* so no wipers,lights,etc etc etc to worry about.
steff...........
wagonist
Post by wagonist » Thu Nov 27, 2008 12:11 pm
What year is the loom?
I remember separating out the EFI loom on one of my previous cars (an 85) so I could later remove it to do an EJ swap.
If its a Series 1 L, it wants power (via the 4th fusible link, not used on carby models) & then gives a feed to dash oil pressure, water temp, ECU & turbo lights. Plus wants input from starter motor wire, A/C wire.
Might be a few others (its been 10 years since I did this...)
BTW, know of any VW forums? I've got a 93 WRX engine with stripped out factory EFI loom & ECU I'm looking at selling.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
gx_rex
Post by gx_rex » Thu Nov 27, 2008 2:22 pm
wagonist wrote:BTW, know of any VW forums? I've got a 93 WRX engine with stripped out factory EFI loom & ECU I'm looking at selling.
aussieveedubbers.com.au
stamp_licker
Post by stamp_licker » Thu Nov 27, 2008 4:01 pm
Yes.You also need the 4 plug afm[hotwire],optical distributer, and ecu .I think everything else is the same.
Building a hardcore postie:D
