Cam belt change procedure 1.8DL Leone..Help
Hi. New to this forum and in need of some urgent advice. I have recently sold my 1.8L DL (1985) and the new owner contacted me in a panic as he has miss timed the cam timing when he had a go at replacing the cam belt. He is in a remote area and so getting to a workshop is not a viable option. I believe he has some mechanical ability and should be able to rectify the problem with some knowledgable advice. Never having replaced a 1.8 cam belt I can't give him the info he needs. Can anyone help with the correct belt fitment procedure or a link to a set of manual instructions, schematics etc... Many thanks folks.
Your best bet is to get a Haynes or Gregories manual.
But here is a quick rundown.
Find top dead centre of Crankshaft. (there are 3 timing marks close together, the middle one is TDC)
Rotate the drivers side camshaft
Now rotate the crankshaft one hole turn till the 3 marks are re-aligned.
Now rotate the passenger side camshaft until the hole in the sprocket lines up the the slot in the top of the cam cover. Put belt on.
Rotate the crankshaft 2 whole turns and double check that the sprockets still line up to their respective marks.
Start engine
Start engine
Cam timing reply
Thank's heaps for the advice. I will forward it on and hopefully he can sort it out from there. Cheers
Also you can have a look at MilesFox's write up on my website http://offroadingsubarus.com/timingbelt_ea82.html about it
Cam belt replacement
Thanks once again. This description is excellent. I will forward the link address on and I'm sure this will get the guy out of trouble.
