rad. switches why 2 on L Series EA82T
Post by steptoe » Mon Feb 16, 2009 12:34 pm
I have got two thermo switches on my L Series sedan turbo with A/C radiator
It has one viscous clutch fan on the water pump and an electrric fan to come on with A/C? and when warmer than quarter on gauge , bout 1/3 it switched fan on before I played with engine
I can understand one thermo switch but not two.
There are wires and plugs off body to connect.
The manual shows the lower one calling it thermo switch. It is just above bottom radiator and faces to the rear. Its wires have twisted and broken off just today . Has sort of braided fibreglass insulators poking out of the switch
The other is same side but higher up and screws into the side of the radiator. Which << EDIT >> I have found the thermo fan will switch on when correct temp so this must be the thermo fans thermo switch !!
Wiring diagrams and manuals not much further help
They are both two wires , so switches and neither are for temp gauge or ECU (I don't think, coz they are below thermostat and on inlet manifold)
Any working knowledge people?
thanks,
if I solve it beforehand I will post up findings see EDIT above
Post by Gannon » Mon Feb 16, 2009 4:05 pm
Not sure why there are 2?
My radiator has 2 holes, one has a thermo switch, the other just has a plug in it.
Maybe whoever had it before you didnt have a plug, so put a spare thermoswitch there instead
BlackMale
Post by BlackMale » Mon Feb 16, 2009 10:20 pm
My radiator has 2 plugs as well however i think that 1 is for the thermo and the other is for a temp gauge. They both have pins however i think from memory i have only ever have 1 wired up.
Post by steptoe » Tue Feb 17, 2009 10:39 pm
Yeah, looks factory, wiring loom goes off somewhere. Car still goes and stops, same too the thermo fan. Which means everytime Ive had the radiator in and out I have disconnected and reconnected this plug for nothing ?
Temp gauge and ECU run off engine and the only other temp warning is in the tranny. I guess that to join the two wires may reveal something.
timmo
Post by timmo » Wed Feb 18, 2009 9:59 am
I thought the 2nd one was a thermo cut out for the A/C, but could be wrong
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
Post by steptoe » Wed Feb 18, 2009 10:14 am
that may be so, good one, I should check the air con circuit diagrams
Post by Gannon » Wed Feb 18, 2009 4:06 pm
Air con should force the fan to come on, regardless of temperature
Just leave the lower one disconnected
timmo
Post by timmo » Thu Feb 19, 2009 9:26 am
no im talking about it killing A/C once temp water temp gets too high. Thermo will still be on regardless of A/C
GU Patrol Ute
Honda XR400R
Post by steptoe » Thu Feb 19, 2009 10:53 am
I understood ya timmo, like a safety cut out.
Have ripped my air con out so won't matter or be able to test this theory. Engine bay looks better without the A/C compressor
wagonist
Post by wagonist » Thu Feb 26, 2009 12:29 pm
Is it still the orginal radiator? I doubt it after all these years.
The series 1 fan switch sits in the back of the tank, whereas the series 2 had it in the side.
They have different wiring plugs depending on which series.
So I think in the aim of simplicity, some aftermarket manufacturers put both spots in their so it didn't matter which car you had.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Post by steptoe » Thu Feb 26, 2009 1:07 pm
what? you don't reckon subie quality will last 20 years and 190,000km ?
thing is not only is the switch there but factory loom hooks up to it!
