How to get door trim off
Help, Can someone tell me how to get the trim off my 93 subaru. Has power windows, I have taken the screw out of the handle area and popped the trim now in stuck. I need to replace door locks and speakers. Thanks.
There is a screw top of handle,
one under the arm rest,
maybe one behind the door handle. Even if there isn't, you still have to slide the plastic out from there, take your time and see how its held in (they're easy to crack)
Three screws below speaker cover area.
Then, run your hand around the outside of the door trim, gently pulling out the clips.
Door trim should lift up with some effort, lift it a couple of inches and only slightly pull away from the door, because, remember you have to, still disconnect the power windows switch and the courtesy light down the bottom of the trim.
- Suby Wan Kenobi
- loz_james
exterior trim?
oi, does anyone know whereabouts i could get a replacement trim for the exterior panel?
the previous owner of my car neglected the old trim which was coming off and now its been weathered and has warped out of shape, therefore no longer sitting flush against the panel
- loz_james
exterior door trim
does anyone know where i could find some exterior trim for a gen2 liberty?
the old trim has come away from the panel and with the previous owner's neglect, has warped and no longer sits flush. re-gluing isnt really an option
