El_Freddo wrote:Ah yeah... I forgot about those little suckers. Shows how long its been since I've split a block. Might have to think up a new project
Sounds like it mate.. How about a EJ25 Turbo from a 03 Foz? I got offered a whole car today for $7,000 complete but damaged (rolled) and was trying to think of what I should build??
maxxair wrote:"I have seen one person replace the big end bearings without splitting the block"
I would love to know how. (not coz im dodgy or anything, just it may come in handy.lol)
I'll need to explain with a picture but you'd remove the sump and slash tray then you can see all the Big End Bearings, not the mains as you need to split the block for them.
tex wrote:Just the seal would be easy but the big end bearing would be a challenge. unless it was the spigot bearing they were changing.
By the way if your going the H6 conversion Tons of labour involved I would imagine it could possibly involve changing the wiring loom behind the dash.
But if you have a manual I'd get a manual H6 to save having to cut out the transmission computer plus if you get something the same age hopefully it will all plug in and bolt up whats more you might get some good bits and sell off the rest!
Not sure Tex what you mean the seal or spigot bearing as this is outside the engine and sandwiched between the block and gearbox? maybe you're not thinking of the same things??
As for the H6 I'd use just the ECU harness (cut down and modified) and drop it over the existing loom so everything else runs as normal and the H6 runs as a stand alone unit. I wish I had the time as this would be an awesome conversion.
Disclaimer: Not my website but
hyperlink here to Subaru workshop manuals
