EA81T Questions
EA81T Questions
A couple of questions for the few people with an EA81T
1. What turbo pressure are you running?
2. What ECU you using?
3. What Valve clearance should i have?
4. Is the oil pump the same as a normal EA81?
5. What head gaskets should i be using?
Thanks
Matt
Thanks
Matt
"Claudia"
"Claudia"
more inportantly howd you score a EA81T!!! lols
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
The right time, the right place and the right price!!!! :P lol!!! I think i have to brag now, i now have in the shed a EA81T and a EA81 Dual port in the shed, both running in the Wagon and my Trust Old heavily modified Brumby!!!! I don't know of anyone else that has the whole set like i do... lol :P
"Claudia"
"Claudia"
1. Standard.. I think it's around 4-6psi. Sorry no gauge and only way I can tell the turbo is boosting is a green light on the dash comes onMatt wrote:A couple of questions for the few people with an EA81T
Thanks
Matt
2. Again standard ECU
3. Mine appear to have Hydralic Lifters as the rockers are factory set.
4. From the outside it looks the same but never pulled it apart.
5. Call Subaru spare parts.. I have a VIN if needed or try Ebay USA
Paul
I have 2.. 1 in a Aussie Touring wagon and the other in a JDM Leone sedanspike wrote:more inportantly howd you score a EA81T!!! lols
If i could grab that VIN number that would be awesome as i think it could be useful..
"Claudia"
"Claudia"
i know of a couple of the duel port ea81s, but never seen the turbo model
GETDIRTYCLOTHING
GETDIRTYCLOTHING
I have an ea81 turbo in the shed that has an aftermarket fuel management system too. It ran a vf2 turbo - whatever is on an ea82t on 10psi. It was on an stock ea81 non turbo block so yeah I used the same oil pump
PM sentMatt wrote:If i could grab that VIN number that would be awesome as i think it could be useful..
What parts do you need?
Yeah.. you are correct but if you find yourself a good parts guy (lucky I do) they will follow it up for yousteptoe wrote:As far as Subaru in Australia are concerned with parts of the EA81 that were not available in Australia they generally don't have listings - like the hydraulic lifters. Could not even find a listing for them on OS markets aftermarket some years back for my import EA81
Does that good parts guy happen to a member here??? :P
"Claudia"
"Claudia"
Nope.. he doesn't own a SubyMatt wrote:Does that good parts guy happen to a member here??? :P
You can always ask me for genuine parts and I'll pass it on
Solid in Dual Parts and EA81T's i believe are the same???
"Claudia"
"Claudia"
Not a bad motor the ea81t,,had one not long ago,mine was running a KB laser turbo carby and went well with the ea82 turbo on it to.,,cheap upgrade is an ea82 turbo,bolts straight on..If your after some parts eg computer ect try TRADEME.CO.NZ its a site like our ebay but its in new zealand ,,these motors came factory in their MY models over there that were built nz new..
Cheers Justin i will keep an eye out. :P
"Claudia"
"Claudia"
I'm 99% sure my EA81Ts are hydralic as there is a sticker on the rocker cover stating something about not adjust the tappets. Never pulled either of mine apart so can't be 100% sure.Matt wrote:Solid in Dual Parts and EA81T's i believe are the same???
