Brumby prop. shaft.
SUBANOOB
Brumby prop. shaft.
Post by SUBANOOB » Sat Dec 18, 2010 10:13 am
Loose universal joints are shitting me to tears... can i drive my beast with the prop shaft removed..?
Post by TOONGA » Sat Dec 18, 2010 10:18 am
not unless you have something to block up the back of the gearbox, eg a dummy shaft because as soon as you take out the drive shaft most of the gearbox oil will drain out.
check to see if your tailshaft has grease nipples if so just fill them up and the noise will stop for a while
SUBANOOB
U.j replace
Post by SUBANOOB » Wed Dec 29, 2010 6:36 pm
Can u replace the uni joints in a 92 brumby?
wrxer
Post by wrxer » Wed Dec 29, 2010 8:18 pm
yep, you can buy them in shops
"UNDERSTEER" is when you hit the fence with the front of the car.
"OVERSTEER" is when you hit the fence with the rear of the car.
"HORSEPOWER" is how fast you hit the fence.
"TORQUE" is how far you take the fence with you.
If it works, pull it apart to see why.
Post by RSR 555 » Thu Dec 30, 2010 9:59 am
Some can be but you'll need to look at your prop shaft. Were the uni-joint cup is there needs to be a c-clip on the inside. If unsure, I'd call RGM and get a quote.. you might be surprised :)
poprock1
Oil leak.
Post by poprock1 » Thu Dec 30, 2010 11:24 am
It appears that the brumby tailshaft is different to the L series. Mine has a two piece shaft with a retained spigot and flange on the gearbox, so the rear shaft can be removed and still driven. Anyone remember the dark ages when most parts interchanged between models?:confused:
kilo
Post by kilo » Thu Dec 30, 2010 4:39 pm
toonga is spot on, best fix is to replace uni joints. cheap n easy to do, jus remember you will need to replace gearbox oil when you finish the job cause you will loose the lot when you remove the shaft.
Post by El_Freddo » Thu Dec 30, 2010 8:23 pm
kilo wrote:toonga is spot on, best fix is to replace uni joints. cheap n easy to do, jus remember you will need to replace gearbox oil when you finish the job cause you will loose the lot when you remove the shaft.
How much oil do you have in your gearbox??? I'd definitely be raising the rear of the car to remove the prop shaft rather than the front, no oil will come out when you do this ;)
And the L series two piece tail shaft is very handy at times for removing the rear diff if you ever need to - like when you weld it up :twisted:
