L Series brake booster in Brumby
- Backyard_Brumby
Hi guys,
Thanks to a very handy new acquaintance I managed to pick up a myriad of parts for the project today. One of which was an L series brake booster, just wondering if anyone has put one in a brumby and how easy it is / is it worth it.
In the brake system am also replacing
Master cylinder
Brake Lines
Rotors & Pads
Rear Shoes
just thought the bigger booster might finish it off nicely as at the moment you would be better off sticking your feet on the ground to slow the car as the brakes are that poor.
Master cylinder
Brake Lines
Rotors & Pads
Rear Shoes
[SIGPIC][/SIGPIC]James
I said dodgy....
Uploaded with ImageShack.us
This thing was stopping an otherwise standard Brumby braked STi powered beast - 320kW @ 20 psi boost
I think you mean 320hp, because 320kW is roughly 430hpsteptoe wrote:This thing was stopping an otherwise standard Brumby braked STi powered beast - 320kW @ 20 psi boost
- Backyard_Brumby
I was under the impression that you could use a Liberty brake booster on an MY when going with a crossbred conversion, so why couldnt an L series booster be used?
Here is a pic of a liberty booster in a M.Y. / brumby . We fitted it up , only have to get the shaft to reach the pedal . That the only mod we did.
We have also fitted a L Series booster to a M.Y. wagon . It took alittle more work to get the shaft to reach the pedal . But it fitted.
rtcb65
Redneck Rick.
Redneck Rick.
- greywarden
Suparoo wrote:I was under the impression that you could use a Liberty brake booster on an MY when going with a crossbred conversion, so why couldnt an L series booster be used?
after reading this thread i am still confuse if i will be liberty brake booster or L series brake boosterDane wrote:I couldn't quite get the L series booster to fit. But I did the rest of what you've mentioned (braided lines?) and it was a massive improvement to brake feel.
- Backyard_Brumby
Turns out after all that, when we took the booster out it seems to be the exact same as the standard so I guess it is just the factory one. Now I am thinking about going and hunting down a lib booster though as i really want better braking
rtcb65 Any chance you have a pic or explanation of what you did as your mod for it to reach ?
cheers
cheers
