EA82 Conversion
EA82 Conversion
G'day all,
i'm new to this online forum thing, so cut me some slack on my first go!
I've got an 87 sportswagon running standard EA82 and 5spd with dual range - I'm very keen to undertake an E82T conversion. I'm currently sounding out the the owner of an 88 leone sedan with EA82T and auto trans to see if hes keen to part with it. Would this conversion be straight forward? ie is the bell housing the same? His car is fulltime AWD, will my part time 'box be ok? Is there anything else I need about this conversion before I commit to the purchase?
Timmo
Timmo
ive done this conversion myself..... if your car is currently a carby motor you will need the EFI fuel tank and pump and the efi computer & loom to fit in the car also.... your standard 5spd dual range box will bolt up without any hassels...
also you need to cut and modify the engine cross member to make room for the turbo up pipe...or unbolt and rebolt a turbo crossmember in
hope this is some help to you....
wrx_nut
wrx_nut
85' Touring Wagon, EA82T, 3" Lift, 27's, RS intercooler
90' Brumby (B&S Project!) still cutting rust :P
Did you wanna keep the slushbox? The dual range is the better transmission in my opinion, would make the conversion a whole lot easier. Do you know what your final drive ratio is?
You've come to the right place anyway, all the regular contributors here have done serious conversions; unlike many forums flaming is also very minimal here (and we'll keep it that way eh SubaMike?!?:p).
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry
- Outback bloke
I think from his post Muddy that he is going to keep the manual in his car. Best advice I can give you is to buy the complete car if you can afford it. That way you know you have got every thing there to do the swap.
Then you basically put every thing in the donor car in to yours except for the gearbox. Swap the complete wiring loom, engine, rear brakes etc in to yours.
Thanks for all the replies fellas,
Definately not going to swap the auto trans Muddy, those things are awful! The thing that daunts me the most however is wiring the thing up, is it a tricky job performing the wiring loom swap? The other things mentioned seem achievable for my modest mechanical skills - i've managed to replace the oil pump seals, timing belt and water pump on the current EA82 without too much drama so it should be alright. Speaking of the oil pump seals, that was the best tip i'd had on fixing the rattle from the hydraulic lifters - apparently buggered seals mean the the oil pump sucks air and that is usually the cause of the clatter that I hear so many EA82s suffering from, not the actual lifters themselves being stuffed as some told me. Anway i think thats enough eh!
