L series: EFI and RX part similarities/differences
Stuff like oil,air, and fuel filters are they the same between NA efi models and RX models? I know spark plugs are different (gaps), and drive shafts. Clutches? radiators? oil/water pumps? belts? etc... Are most things that are not directly turbo related just the same as NA EFI stuff?
Off the top of my head...
Oil – Will depend on what you run now. My guess would be yes oil will be different.
Air filter, Fuel filters, Clutch - Will depend on what you run now, although it should be the same.
Drive Shafts diameter and cup’s can be different (this also includes radius rods – RX 1’s are bigger diameter).
Radiator – Will depend on what you run now, if you do not have a twin core rad then I would suggest 1 for the RX, make it mandatory if your going to be running the air con stuff as well.
Oil and Water pumps should be on the RX engine, from memory they are the same but don’t quote me on that 1 its been a looooong time since I have seen the mpfi NA gear.
And after some though i think that my 82t water pump was replaced with a new na 82 unit.
after all the engine is the same just forced. I found water pumps are the same,as n/a , just check to ensure you have a deck height of 110mm not 105mm for that is for the flat ribbed belt (ah shoot, I missed an ebay item), oil filter and pump appears oil the same Z493, even an efi head can be drilled and tapped to become a turbo head. Yours may be different though coz it was the AWD 4 speed auto L series.
