looking for speedo check around brisbane
does anyone know if there is still a speedo check set up on the bruce highway north of brisbane, just wondering if my oddometer is miles out and would like to check it over 5 or more k's.
If its not there does anyone know where the main roads dept have set one up around brisbane?
there is an odometer check north of brisbane headin south between anzac rd ish and pine river ish last time i was done. been a while though...mighta changed with all those roadworks...
cheers
cheers
Dl l series wagon
2 inch cat back exhuast, 32/36 weber,
CD player, tacho, polyurethane bushes, spotlight, air horns
- The Bigfella
Grab an GPS from ebay.. would be worth getting, i use it all the time for work related - distance of kilometres etc and I travel speed camera/time zones and relies on GPS for speed.
My Liberty would be doing 107kmh where the speedcheck says 98 whereabouts GPS says I'm doing 101. SPeed check is estimation purposes.
- The Bigfella
- SUBYDAZZ
GPS is likely to be the most accurate reading you can get. And yes, car speedos vary in accuracy at different speeds. They are usually spot on closest in the range of 70-100km/h from experience and the further either side the larger the error, generally. ADRs require tolerance of +/-4% from memory. And the tyres can be another +/-4% out too! This is why that most radars / speed cameras are set at 10% above the posted limit.
SUBYDAZZ
