HELP, timing mark reference on ea82t
SCOOBIDOO
Post by SCOOBIDOO » Wed Apr 15, 2009 7:06 pm
Thanks for looking anyway all...ill borrow a subaru flywheel and make my own timing indicator
that way i can notch my harmonic balancer with small v markings and ill be good to finish the assembly on this brand new ea82 t...cheers
THE FASTER THE SPEED - THE BETTER THE IMPACT...SUBARU
Post by Gannon » Wed Apr 15, 2009 8:31 pm
This may be a silly suggestion,.. but if you cant shine the timing light in the hole at the top of the flywheel, can you use a small mirror to reflect the light into there?
Post by steptoe » Thu Apr 16, 2009 8:51 am
SCOOBI has this engine intended for a MANX if I am not wrong, it may just be impossible to even see the timing aperture if he had any corresponding timing marks on it.
SCOOBI PM me your mailing address and I can send you your very own flex plate off an auto EA82T with timing marks and timing belt install marks as well. Maybe you could adapt it to fit to engine side of your flywheel in use ?
SCOOBIDOO
Post by SCOOBIDOO » Sun Apr 19, 2009 6:55 pm
Thanks anyway but the job is now done, i dont use the subaru bellhousing even,so there is no point shining a light there.
The adapter goes straight to the block..and this is the third conversion i have here.
Just wanted to know exactly where everything is,and now i do..cheers.
Post by steptoe » Sun Apr 19, 2009 8:04 pm
and you have shed a bit more light on the subject there SCOOBIDOO - the old 'no aperture to shine timing light' predicament [ :) sorry been watching Agents 86 & 99 ]
nncoolg
Post by nncoolg » Tue Apr 21, 2009 5:54 pm
..what's going on instead of the bell housing?
Post by steptoe » Tue Apr 05, 2011 9:06 am
An update on the timing pointer for the front , never came from Japan, so figure no longer available
FROG
Post by FROG » Tue Apr 05, 2011 12:27 pm
Correct Jonno 21171aa001 that you mentioned is no longer available I had a look this morning
