they are narvas.2nd Hand Yank wrote:^^ Alex, what kind of lights do you have turned on, under the bumper of "Wanky Wagon?" Looks brighter than your low beams.
awesome lights
i have the same set (came in a red box) they are great as at the time i required a hex head socket rather than a star style which my whole sidchrome set is. (was stripping bolts)niterida wrote: So I went out and bought a Supatool (made by Kinchrome did you know) impact socket set for $30.
by hex head you mean flank or wall drive - they have little recesses right at the corners so that no pressure is ever placed on the corner of the bolt and should therefore never slip or round off. Also called 6 point but I don't think 6 point has the corners recessed.Alex wrote:i have the same set (came in a red box) they are great as at the time i required a hex head socket rather than a star style which my whole sidchrome set is. (was stripping bolts)
I thought the 12 point had better grip than the 6 point, with some pressure on the sidewall.niterida wrote:by hex head you mean flank or wall drive - they have little recesses right at the corners so that no pressure is ever placed on the corner of the bolt and should therefore never slip or round off. Also called 6 point but I don't think 6 point has the corners recessed.
by star style you mean 12 point - these only drive on the corners of the bolt - which is why they can slip and round off the bolt. They do make it easier to put the socket on the bolt though....
personally I think the impact sockets provide the best grip - they are basically the same as the expensive Metrinch and other non-slip designs.2nd Hand Yank wrote:I thought the 12 point had better grip than the 6 point, with some pressure on the sidewall.
I feel like returning my 1/2" drive set now.![]()
If I had to own one set, I'd prefer the best grip.
Yep, I have the sizes you mention. I wonder what I did before. Probably swore more and drank more beer.Silverbullet wrote:A bit of subject change I know but, how many of you guys have ratchet spanners? Experiences? We've got one, the most useless size of 13mmI keep thinking I need to buy a 10, 12 and 14mm but they're about $30 each
Would make life so much easier though...
Would just be easier to use than a normal spanner. Like where socket won't fit you can use a ratchet spanner. With a normal spanner it's loosen 1/4 turn, remove the spanner and replacing it again for another 1/4 turn, gets tedious real fastniterida wrote:I'm about to buy a set of flex head ratchet spanners. Think about it - when do you really need the ratcheting action ?
Yes i realise that - what I was getting at is when you really really need the ratcheting is when you probably also need the flex head - so I wouldn't bother with fixed head ratcheting spanners when you can buy flex head ones.Silverbullet wrote:Would just be easier to use than a normal spanner. Like where socket won't fit you can use a ratchet spanner. With a normal spanner it's loosen 1/4 turn, remove the spanner and replacing it again for another 1/4 turn, gets tedious real fast
Ah I see, fair point.niterida wrote:Yes i realise that - what I was getting at is when you really really need the ratcheting is when you probably also need the flex head - so I wouldn't bother with fixed head ratcheting spanners when you can buy flex head ones.
Lifetime OR until you use it?TOONGA wrote:Warning thread hi-jack
I climbed on the cheap tool bandwagon todayexpendable tools
the ratchets are stanley and the spanners (ratcheting) are super cheap. all together it cost 127 dollars, the stanley stuff has a life time warranty or until you use it.
I'm envious mate. I hope they last you longer than you expect them to.the stanley stuff worked out to 1 dollar a tool, 69 tools for 69 dollars. the spanners were a little more expensive at 4.91 each.
but when you look at replacing snap-on sockets at around 22 dollars each or a ratchet at around 250 dollars. I think I would prefer to lose the stanley and SCA brand stuff.
This way I don't worry about leaving my snap-on or gearwrench tools in the car
