wanky wagon new motor ideas?
which motor?
ej20g
3
9%
ej20g
10
29%
ej20g
8
24%
ej20g
13
38%
Total votes: 34
adamb
Post by adamb » Fri Mar 14, 2008 7:11 pm
hi alex,
im just finishing off my turbo conversion now and i can tell u its frickin scary as driving it with shagged suspension and no wheel alignment haha. But well worth it, id say go turbo conversion just so u can laugh at VL turbos when u beat them.
Adam
L Series current mods:
EJ20G, 3" lift, Roo bar, spotties, EJ Sporty steering rack, desert rats, 27" tyres, 2.5" exhaust
Post by El_Freddo » Fri Mar 14, 2008 10:12 pm
D3V1L wrote:hahah matty boy u dont understand how different boxer motors are
to get the rods out the motor has to be stripped of nearly every nut and bolt AND the block needs to be split into its 2 halves....
a big task at hand but not undoable
i think a rebuild is a better idea as well
The EA's don't have to stripped down to get the rods out - just the heads off, I'm guessing that the EJ would be no different... But i reckon if he's going to that extent you might as well split the block and stick some new bearings on the crank too.
Obviously a replacement EJ22 would be the quickest, but...
Just turbo the bitch!
Bennie.
gx_rex
Post by gx_rex » Fri Mar 14, 2008 10:29 pm
or rebuild the EJ22 with forgies and turbo that.
subanator
Post by subanator » Fri Mar 14, 2008 11:21 pm
EJ22 is pretty bullet proof, can take a fair hiding, but the EJ20G will just give the rest of you car a hiding and be forever fixing stuff.
Post by El_Freddo » Sat Mar 15, 2008 12:51 am
subanator wrote:the EJ20G will just give the rest of you car a hiding and be forever fixing stuff.
I think alex is already fixing stuff - just look at the EJ he's dropped in there... and if he's not fixin' stuff, he's polishing stuff :rolleyes:
Post by D3V1L » Sat Mar 15, 2008 10:24 am
wrong..... have to split the block with ej motors. very different to ea motors
trust me ive just done one and have the manuals for all the motors
dave
El_Freddo wrote:The EA's don't have to stripped down to get the rods out - just the heads off, I'm guessing that the EJ would be no different... But i reckon if he's going to that extent you might as well split the block and stick some new bearings on the crank too.
Bennie.
vidler
Post by vidler » Sat Mar 15, 2008 11:02 am
from where your car is at the moment an ej25 will be an easy fit compared with the ej20g.
plus you can keep the same box, and you'll get shit loads more torque....
09 Forester XT Touring Wagon
Post by AndrewT » Sat Mar 15, 2008 11:17 am
I don't rekon the EJ25 is enough of an upgrade to justify the swap. Maybe if you can get one for the same or similar price as an EJ22.
The EJ20turbo will be a very easy upgrade. It will run off the same wiring loom with a few minor additions for the boost solenoids. You would need to upgrade the clutch and either modify the engine crossmember or get a turbo one.
EJ20turbo will blow you away but if you stick with the EA driveline be prepared for significantly more breakages then you already get! :)
It's worth noting that my wagon hasn't suffered any breakages at all that can be directly attributed to having an EJ20turbo - without even running an engine stayrod. Perhaps it is driving style, not too sure, you all know I don't really hold back. I can't imagine the Outback gearbox I'm using is a huge amount stronger than an L series one but running in front wheel drive on an L series box does take it's toll on the gearbox itself and the chassis of the car due to the twist from the extra torque.
Phizinza
Post by Phizinza » Sat Mar 15, 2008 3:47 pm
I'd just get a low k import EJ22. Throw it in and drive..
Post by AndrewT » Sat Mar 15, 2008 3:56 pm
fyi I have found EJ22's are quite rare at import yards and usually very expensive. Much better off sourcing one from a locally smashed or wrecked car.
90brumby
Post by 90brumby » Sat Mar 15, 2008 4:25 pm
ive got 3 ej22s here atm the brumby only needs 1
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Matatak
Post by Matatak » Sat Mar 15, 2008 4:32 pm
if u go for a new EJ22.
then u may need another Series 1 engine as the Wiring Loom on a Series 2 is a bit different.
it can probly be worked aorund quite easy but u better find out first.
Subarino shuld no.
also a series 2 engine is a better one :)
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AndrewT » Sat Mar 15, 2008 4:37 pm
5 minute job to swap over the little harness that runs under the inlet manifold pretty much to change between S1 and S2 I believe.
Matatak
Post by Matatak » Sat Mar 15, 2008 4:47 pm
well if thats all it is :p
then nothing to worry bout.
90brumby
Post by 90brumby » Sat Mar 15, 2008 5:42 pm
wat is the main differerence between s1 and s2 motors ive got em both here i wanna no which 1 to put in the brumby
Matatak
Post by Matatak » Sat Mar 15, 2008 5:45 pm
Go the series 2.
i no its got bigger injectors (i think its 280cc as opposed to 220 in S1. but aint sure on figures).
cant think of nething else tho atm lol
TARMAKH8R
Post by TARMAKH8R » Sat Mar 15, 2008 6:58 pm
wanky wagon with gate ? :)
Post by AlpineRaven » Sat Mar 15, 2008 10:36 pm
Matatak wrote:if u go for a new EJ22.
Subarino shuld no.
Whats the difference between series 1 and 2?
Matatak
Post by Matatak » Sat Mar 15, 2008 10:46 pm
showthread.php?t=9300
thats bout all i no.
and theres a few more with the Gen1 and 2's that ive seen
BrennyV
Post by BrennyV » Mon Mar 17, 2008 9:20 am
let him get a turbo! u know how bad he wants a bov ;)
Hunter S. Thompson
