4wd light brumby dash
The 4WD light on the dash of the brumby is always on, when I got the car I remember the bloke muttering something about having to cable tie the switch every now and then. this ring a bell with anyone?
The lever closes the switch when it is horizontal, it is likely the switch is slightly out of position or has a broken clip. You can pick up a replacement from a wrecked MY, it's about a 5 minute job to change it. Note that the early MY switch and late Brumby switch are the same but the wiring method changes (from solder to crimp from memory), so you may need to cut & solder the 2 wires.
Dean.
Dean.
