Santa brought me a REAL 4wd for Christmas!
Posted: Sat Dec 27, 2008 10:42 am
by Ben
Had it bogged to the sills on Stockton already. BTW Stockton is a cut up bitch of a place right now! The dunes weren't bad I got stuck going a little too close to a drift drop off and the turbo diesel didn't have the herbs to keep me moving. The Patrol recovery vehicle was present though (Dad has a kick arse Prado) that made short work of snatching me out.
Posted: Sat Dec 27, 2008 11:06 am
by AndrewT
unlucky....
Posted: Sat Dec 27, 2008 12:19 pm
by vincentvega
you farking what???
Posted: Sat Dec 27, 2008 12:53 pm
by beastofburden
paaah toolyota,s and pootrols more fun in a soob lol
Posted: Sat Dec 27, 2008 1:05 pm
by Outback bloke
I s'pose it is better than a Toyota.
Posted: Sat Dec 27, 2008 1:20 pm
by Matatak
well....i like it
they are the 3.0TD's arent they
Posted: Sat Dec 27, 2008 1:47 pm
by Ben
Matatak wrote:well....i like it
Nah, no way I was touching the ZD30 timebomb! It's the old skool RD28 6 cylinder diesel with a paltry 95kw/252nm, does alright lugging 2300kg of truck around though. About the same as the brumby for get up and go.
Anyone asking the 'why' question...
A growing family means the brumby is less and less favourable. And the Outback isn't a brilliant tow vehicle, although rated to tow 1600kg it doesn't much like the 900 or so I put behind it. I needed something family friendly, with good towing capacity, good offroad ability in
standard form, good economy and reliable. GU Patrols tick all of those boxes...
Posted: Sat Dec 27, 2008 2:22 pm
by Suby Wan Kenobi
I dont know weather to congratulate you or not but if your happy then its all good.
Posted: Sat Dec 27, 2008 3:25 pm
by subiwidow
For that quote, he should loose all moderator privligies..
Hope Michelle and Lachlan had a wonderful christmas, you were obvious way to wasted and got led astray.
Posted: Sat Dec 27, 2008 4:22 pm
by Captain Obvious
Ben wrote:Nah, no way I was touching the ZD30 timebomb! It's the old skool RD28 6 cylinder diesel with a paltry 95kw/252nm, does alright lugging 2300kg of truck around though. About the same as the brumby for get up and go.
A growing family means the brumby is less and less favourable. And the Outback isn't a brilliant tow vehicle, although rated to tow 1600kg it doesn't much like the 900 or so I put behind it. I needed something family friendly, with good towing capacity, good offroad ability in standard form, good economy and reliable. GU Patrols tick all of those boxes...
i agree ben, always loved patrols, i know i a few little tricks to get that 2.8 to go a little better!! they are my pick for a big 4X4
Bryan
Posted: Sat Dec 27, 2008 7:23 pm
by Outback bloke
They are my choice too, I just wanted to do a bit of stirring. The only thing I don't like is the disease-al bit.
Posted: Sat Dec 27, 2008 9:15 pm
by vincentvega
common theme here - I would also drive a patrol if i was to buy a big rig.
Also whats wrong with the 3L Ben - the one in my old man's Navara is tops. I think they are too small to be pushing a patrol but they are well suited to the navara.
its a real shame they stopped producing the 4.2 diesel patrols.
Posted: Sat Dec 27, 2008 9:44 pm
by Ben
Navara runs a conventional wastegate setup and the patrol runs a variable nozzle control system, the maf and egr control boost via the ecu and it isn't uncommon to see boost in the 20's on a Patrol ZD30 (15psi on a Navara), when the maf fails boost pressure goes nuts and the egr directs more exhaust to piston 3/4 and ends up in one of those pistons going pop. This is what I have figured out from the research I have done. ie D22 navara is all good, GU2+ is no good... I guess that is why nissan has dumped the ZD30 after one vehicle cycle and gone to the 2.5L crd...
by brumbyrunner
Ben wrote:Nah, no way I was touching the ZD30 timebomb! It's the old skool RD28 6 cylinder diesel with a paltry 95kw/252nm...
Time bomb on early 3 litres is right. So too the 2.8s. You couldn't give me one! I have seen far too many needing a tilt-tray ride home. Best of luck with it, I hope it serves you well, just don't get up it too much.
Posted: Sat Dec 27, 2008 10:29 pm
by AlpineRaven
Good Luck with 3.0TD!
Posted: Sat Dec 27, 2008 11:14 pm
by vincentvega
who was that really useful post aimed at?
DA
Posted: Sat Dec 27, 2008 11:54 pm
by T'subaru
Suby Wan Kenobi wrote:I dont know weather to congratulate you or not but if your happy then its all good.
"You gotta love this guy"
Posted: Sun Dec 28, 2008 9:46 am
by subarooster
very nice ben, but down the track you'll be driving along and you'll think, i wish this tank was as nimble as the brumby.
Btw: gannon said that he will be going for a 22 in his leone soo i'll definately buy that engine off ya. cheers
Posted: Sun Dec 28, 2008 12:41 pm
by tex
The old poo trols is a good option of a stock as a rock 4x4 in my opinion too well better than a land bruiser anyway! But sounds like you can still run around in the brumby as a weekender or for some fun!
By the way just checked out your signature just goes to show I don't listen to good advice!
