First one to identify this, wins.....
A free EA82 part of their choice from my shed (subarooster is not included in this competition)
Hint.... its an OEM part
- subarooster
- subarooster
re: identify this
is it exhaust manafolt and turbo from new diesel subaru,
- phillatdarwin
it cant be from diesel.....
Isnt that from 2010 Liberty/Legacy turbo?
its wacky hey. Here's a pic of how it looks on the engine with the turbo there...
I'll definitely need a really good bash plate when I put one of these motors in my wagon
chuckles....
YEah nice looking engine and its completely different.. At first I thought it would've been triple turbo but nah... I knew it wouldnt be diesel because ive already seen the diesel engine and it doesnt have that thing on exhaust.
Fats had it first.
AP was on the right track and Andrew hit the nail on the head
Yeah its the 2010 Legacy B4, strangely its not a twin scroll.
Power figures of 210Kw and 350Nm between 2000rpm and nearly 5000rpm
*winks with a grin*Suparoo wrote:Fats had it first.
Nice nice...
- discopotato03
Interesting that it's not twin scroll , would be very easy with a suitable turbine housing to make it TS .
One engineering prob to solve with a low mounted turbocharger is it's oil return to the sump as oil won't gravity feed sideways or uphill , frothy oil foam ex turbo anyway .
One thing that's always been an issue for Subaru flat engines , turbo anyway , was the unequal length header pipes - and the dodgy method of only having one pipe from each heads pair of exhaust ports .
Aside from better developed combustion chambers and porting this aspect ain't a lot better than an EA82T - granted the 82T's header junctions are a lot worse .
What they got was the wrong pairing of cylinders given their firing order .
When you do it like that exhaust gas scavenging isn't real good and to a degree performance and fuel consumption will suffer .
Subaru's never seem to have been class winners when it comes to fuel consumption and I'd say Fuji can't afford to ignore this any longer .
To get the exhausts engine pipes close to the same length I suppose the turbo had to go forward because it'd be too low under and behind the engine and nowhere to put it above . Going forward and low is all you can really do on a flat four to make the packaging work .
I guess the rub is that being where it is will be an issue if you hit something hard enough because it may well spear it back into the sump , along with that front mount looking thing .
Cheers A .
Cheers A .
heh I really had no idea at all, I just searched google for a couple of minutes based on the filename of the jpg image you posted and found a forum thread about it with a few extra pics
You sneaky buggerAndrewT wrote:I just searched google for a couple of minutes based on the filename of the jpg
