This is gonna sound odd...I am trying to get a remote oil filter for the EA82 and you have to get a universal one, so I just have to make sure the center of the mounting face isnt too large for the EA82 oil filter gasket. Does anyone have a oil filter they can measure the ID / OD of the gasket? I would prefer it if you could measure a genuine one, as that is what I will be using, but I imagine the generic ones would be similar...
thanks!
Anyone have an oil filter handy?
# EA82 AWD 4EAT,
If you have them please PM me
# EA82 AWD 4EAT,
Damn.. just left the shop 30 mins ago. I know I should have checked AUSubaru before I left
Will check tomorrow if no one else has replied.
50mm id 62mm od
The outer 55 to 62 mm of the washer gasket is in the O ring form theinner bit is flat.
total height 100mm, 83 dia for case itself
Yeah, it is 8.30 on a Sat morn too
MAX Olfilter Nippon Max Series WZ493
Share what you find fits too won't you !
Reminds me, my temp EA82T due for oil change and swap out for my better motor. Loyalty and short of time says change oil, thrill seeker side syas swap motors lazy bastard!.
- TOONGA
at ryco they have a little search device which lets you find similar size filters which will have different characteristics
http://www.rycofilters.com.au/catalogue/dimension
so if you use for example the search criteria of the brumby
http://www.rycofilters.com.au/catalogue ... /part/Z493
and enter them into the search engine you end up with a list of similar filters
