oil pump removal L series.
- hughybabes
Have decided to replace seals in oil pump while doing the timing belts. What is the best way to remove the drive cog ???? Have tried leaving the belt on but it just jumps a tooth when I turn the nut. Is it a normal thread or reverse thread ?
1984 sportswagon
ea81 twin carburettor motor.
"d-shaped" siamese exhaust port heads.
mild low torque cam. electronic dizzy.
2.5 inch engine pipes; 2.25 tail pipe; rear sports muffler.
Normal righthand thread (lefty lucy).. so just need to stop the belt from slippinghughybabes wrote:Have decided to replace seals in oil pump while doing the timing belts. What is the best way to remove the drive cog ???? Have tried leaving the belt on but it just jumps a tooth when I turn the nut. Is it a normal thread or reverse thread ?
Yep.. but I'm guessing that because it has timing belts then it won't be a EA81tony wrote:not sure of the ea81 but the ea82 you have to give it a sharp knock with a hammer or something, maybe use a long bar to get to it. normal thread.
