oil pump removal L series.
Posted: Sat Apr 24, 2010 11:12 am
by hughybabes
Have decided to replace seals in oil pump while doing the timing belts. What is the best way to remove the drive cog ???? Have tried leaving the belt on but it just jumps a tooth when I turn the nut. Is it a normal thread or reverse thread ?
Posted: Sun Apr 25, 2010 12:14 am
by tony
not sure of the ea81 but the ea82 you have to give it a sharp knock with a hammer or something, maybe use a long bar to get to it. normal thread.
Posted: Sun Apr 25, 2010 9:52 am
by RSR 555
hughybabes wrote:Have decided to replace seals in oil pump while doing the timing belts. What is the best way to remove the drive cog ???? Have tried leaving the belt on but it just jumps a tooth when I turn the nut. Is it a normal thread or reverse thread ?
Normal righthand thread (lefty lucy).. so just need to stop the belt from slipping
tony wrote:not sure of the ea81 but the ea82 you have to give it a sharp knock with a hammer or something, maybe use a long bar to get to it. normal thread.
Yep.. but I'm guessing that because it has timing belts then it won't be a EA81
