liberty ej25 auto conversion to wrx ej20t manual
mickey1
Post by mickey1 » Thu Apr 29, 2010 8:51 pm
hi i have possibly done a head gasket or something, and am not to pleased with the auto. so i am looking at a wrx half cut. but i am unsure about wiring and diff ratios and what changes i would need to make to the drive line. any assistane would be appreciated. thanks.
Post by RSR 555 » Thu Apr 29, 2010 9:27 pm
Hi Mickey and welcome to AUSubaru :)
I think some more info like what model car you have and are you planning to do this yourself or get the work done by someone else? and also what do you want out of the car in regards to the final product?
Start with this and will go from there :)
mickey1
Post by mickey1 » Fri Apr 30, 2010 6:19 am
i have a 97 rx liberty wagon. i am looking at doing it myself with some help from a meachanic. the end product hopefully i want be be reliable more so than super quick. some people have said that it is easy, but im not so sure. thanks.
Post by RSR 555 » Fri Apr 30, 2010 3:49 pm
Ok cool.. the 97 RX Liberty is a nice car to use for a conversion.
If it was me, I'd be looking for a Version 3 to Version 6 STi halfcut with matching rear diff (make sure you get the rear CV shafts as well). These are not too hard to find :)
mickey1
Post by mickey1 » Fri Apr 30, 2010 6:12 pm
you wouldn't happen to know how much a cut and diff would be? the sti version sounds like it might be out of my price range:( i was maybe looking at a stock version. trying to not have to change too much with my original driveline. this is something i was looking at doing later on but my hand has been forced. so money is tight.
would i have to change much of my driveline with the standard ej20t?:)
Post by RSR 555 » Fri Apr 30, 2010 6:59 pm
You will be looking at around $2500-$3000 for a WRX EJ20T and around $4000-$8000 for a STi EJ20T :) I would not try and use the early RS EJ20T for a couple of reasons, I'd also not look at the Twin Turbo unless you want to have lots of headaches when things don't work.
As for what you'll need to change in the driveline is everything up front (including wiring), gearbox and rear diff. There is lots of swapping over and I can advise more when the time comes around.. until then it will be just mumbo jumbo ;)
mickey1
Post by mickey1 » Sat May 01, 2010 9:44 am
thanks for the advice, once i get the money together i will be in touch.:D
Post by RSR 555 » Sat May 01, 2010 10:39 am
No probs.. How long away do you think you'll be? Not trying to be nosey but just being inquisitive :cool:
mickey1
Post by mickey1 » Mon May 03, 2010 5:44 pm
hi hopefully around tax time i should have the money, but i will start buying other part like the rear diff and timing belt etc. would i have to get a new tail shaft bieng from auto to manual? thanks again.:)
tex
Post by tex » Tue May 04, 2010 10:05 am
What about gettin a EJ 25 turbo? granted you'll probably have to muck around sending it to an auto electrician but it'd be worth it!
Just food for thought...
87 targa brumby (Neglected),
+ others.
Post by TOONGA » Tue May 04, 2010 10:28 am
mickey1 wrote:hi hopefully around tax time i should have the money, but i will start buying other part like the rear diff and timing belt etc. would i have to get a new tail shaft bieng from auto to manual? thanks again.:)
yes you will need a manual tailshaft as the auto tailshaft is a different length
Post by RSR 555 » Tue May 04, 2010 1:08 pm
Sorry mickey1.. missed your question but like Toonga said.. you will need to change the tailshaft aswell :)
Will be watching out to see how this conversion goes :cool:
mickey1
Post by mickey1 » Tue May 04, 2010 7:09 pm
thanks heaps:D i will start getting the parts and cut and will be in touch. thanks again:-D
