Difference between Foz and WRX EJ20G's
Post by Gannon » Tue May 11, 2010 8:50 pm
I have a mate who is convinced that he has a 2000 WRX engine in his VW notchback
I rekon its a GT Forester motor.
It was a crate motor, is controlled by a haltech, has TGV delete and a RS WAIC and a VF34 running 22psi and makes 260whp through a VW Combi gearbox with straight cut gears
He showed me the turbo that came off it, it was a TF035, it also had an EGT sensor and an up-pipe pre-cat.
He is still convinced its a WRX motor.
Whatta ya reckon?
Is there another way to tell?
Post by RSR 555 » Tue May 11, 2010 10:18 pm
AFAIK.. they are the same.. it was the ECU that was tuned different :???: but I'm not 100% sure
lovey80
Post by lovey80 » Tue May 11, 2010 10:38 pm
As far as I understand it. The diff between a WRX an XT forester is the computer and size of the turbo. Don't quote me on the details though.
Post by Gannon » Tue May 11, 2010 11:04 pm
Im referring to the 2.0L Forester GT's and 2.0L WRX's
Ive read that the cams are different, but is there a way to know from the outside?
My mate mentioned something about some lines moulded on the cam covers.
Post by RSR 555 » Wed May 12, 2010 12:47 am
Yes.. 2.0Ltr GT Forester and 2.0Ltr WRX are the same engine but they have different ECU tunes and I forgot that the turbos are also different.. Camshafts may be slightly different but not enough to notice the difference.. Cam covers are no indication.. Early EJ20T had lines on the top of the cover and smooth below.. late EJ20T have smooth on the top and bottom of the covers.. this is for Forester and WRXs
The only other way to tell, is to give Subaru the year of manufacture (of the engine) and engine number :)
Post by Subafury » Wed May 12, 2010 7:49 pm
ur correct in the tf035 is the gt forester turbo. im pretty sure no other soobies use it so going by that my bet is on GT foz also.
81GGR
Post by 81GGR » Thu May 13, 2010 4:34 pm
gt foz i think - but it is not easy tot ell from the outside. being a crate motor i presume he got the turbo with the motor. the td035 is not used on any model wrx. but the gt's don't have tgv's either so not sure why he has tgv deletes - who knows!
the cams and heads are very different to the wrx of the same area. slap some wrx heads and cams and a td04l turbo on it and it will still spool fast and make about 70hp extra : )
Post by Gannon » Thu May 13, 2010 5:42 pm
Didn't Subarino do a TGV delete in his Foz not long ago? AUSubaru.com/forum/showthread/Am I Kidding Myself??
Thanks for the input guys
Post by TOONGA » Thu May 13, 2010 9:06 pm
yes he did Him and Paul did it apparently it runs way better now
