Forrester wheels on a 1992 liberty FWD
Posted: Wed Jun 02, 2010 11:23 am
by graham7773
Need a quickish answer to this enquiry as the seller wont hold them. As the title would suggest, will 2002 Forrester wheels fit on a 1992 Liberty GX FWD?
Posted: Wed Jun 02, 2010 12:38 pm
by 78sti
SURE WILL!
If you use the forester tyres the speedo will be out as they are a bigger diameter than the liberty wheels
Posted: Wed Jun 02, 2010 6:08 pm
by ScubyRoo
if they are air strut then nope, the tires will hit the strut... if their coil, I doubt it, 16" rims are pretty big... what size tires did you want to run?
Posted: Wed Jun 02, 2010 6:15 pm
by graham7773
Tyres are 215 X 60 and they come with the rims
Posted: Wed Jun 02, 2010 6:43 pm
by DavesB4
graham7773 wrote:Need a quickish answer to this enquiry as the seller wont hold them. As the title would suggest, will 2002 Forrester wheels fit on a 1992 Liberty GX FWD?
Forester and Outback are usually +48 offset whereas Liberty and Impreza ones are +55. You will widen the track some if you bolt them on.
My RS liberty has 235/45x17 tyres on WRX rims and they 'nearly' don't touch a stock strut or the guard.
Posted: Wed Jun 02, 2010 10:20 pm
by vincentvega
they will fit, although you may get some rubbing of the tyres on the body. why do you want to run taller tyres on a FWD car?
AWD / FWD front struts are the same and will clear 26" tyres no problem.
FWD rear struts have more clearance than AWD ones... so you are sweet there too.
no airbags in FWD cars.
Posted: Thu Jun 03, 2010 8:51 am
by graham7773
Doesn't matter, wheels gone. Thanks for the advice
