liberty ski fx 1996 ecu
monkers
Post by monkers » Fri Jun 04, 2010 5:50 pm
hi,
iv got a liberty skifx lx 1996 and im attempting to set up a centrafuse system in it, i was wondering where the ecu is and does it have obd ii?
Post by Gannon » Fri Jun 04, 2010 6:36 pm
Im assuming that Centrafuse is a program you install on a mobile pc for playing music and video in your car.
The ECU is either up beside the steering column or under the carpet in the front of the passenger side foot well
OBDII wasnt introduced into non turbo Subaru's in Australia until about 2003 (i think turbo models got it around 1998 ) Before that it was just SSM (subaru select monitor) which is a Subaru based data code based on TTL serial data transmission.
Post by AlpineRaven » Fri Jun 04, 2010 9:44 pm
It's located under the carpet on passgener's footwell. And it doesn't have OBDII
vincentvega
Post by vincentvega » Fri Jun 04, 2010 10:19 pm
I sell data cables for these early ecu's. I also run a PC in my car.
the best you are going to do software wise is http://www.vwrx.com
head on over to http://www.rslibertyclub.org forums and search for my username and also "Impakt"
I sell data cables, he sells stand alone display units
monkers
Post by monkers » Fri Jun 04, 2010 10:21 pm
thanx for the help guys really appreciate it
monkers
Post by monkers » Fri Jun 04, 2010 10:23 pm
keep getting a 404 error on http://www.rslibertyclub.org is it down?
[edit]
works now..
monkers
Post by monkers » Sat Jun 05, 2010 1:46 am
where exactly under the carpet is it? i pulled up the front part under the dash and there didnt appear to be any plugs. also what kind of plug am i looking for, im pretty new to this, my skills are more computer based, and theres not a lot of information straight up on SSM
Post by Gannon » Sat Jun 05, 2010 7:40 am
It will be underneath a metal plate pretty much at the front of the footwell where it joins teh firewall at a 45 degree angle
http://www.mp3car.com/vbulletin/centraf ... lmost.html
http://www.mp3car.com/vbulletin/engine- ... tocol.html
http://www.vwrx.com/index.php?pg=selectmonitor
Post by AlpineRaven » Sat Jun 05, 2010 7:41 am
monkers wrote:where exactly under the carpet is it? i pulled up the front part under the dash and there didnt appear to be any plugs. also what kind of plug am i looking for, im pretty new to this, my skills are more computer based, and theres not a lot of information straight up on SSM
You might need to pull up further, its under a floor of metal that is bolted down to protect the ECU.. the wires runs towards the right towards transmission tunnel.
