my rx impreza
Posted: Wed Mar 15, 2006 9:37 pm
by tfiddy
ive just picked up an 01 rx impreza and im lookign to put an exhaus ton it.. ne 1 got any advice with exhausts??
Posted: Wed Mar 15, 2006 9:40 pm
by MUDRAT
Yep, my experience would say a 2.5" system from the cat back with a turbo muffler would be perfect.
Have you checked out the "Exhausts" forum?
Posted: Wed Mar 15, 2006 9:41 pm
by tfiddy
nar not yet.. ive only just joined.. wotta u rkn about puttin a wrx cam in it??
Posted: Wed Mar 15, 2006 9:43 pm
by MUDRAT
The thing is a WRX cam is really suited to a turbo motor, so you'll actually loose power.
There's a lot of different forums on all sorts of topics we've got here . . . you should take a look around.
We've also got a pretty active WA crew you could hook up with.
Posted: Fri Mar 17, 2006 9:05 am
by AndrewT
I don't think that is possible.....a WRX 2.0 engine is DOHC and I'm pretty sure an Impreza RX's is a SOHC. Mabey it's possible to swap the entire heads but as Muddy says, you would infact loose power.
Welcome to the forum, hope you find some other good info...check the WA section for info on cruises (although a little dormant at the moment).
