Forest GT's - no cruise control?
I have been looking around at a few forester GT's and none seem to have cruise control. Is this real? they did not come with cruise
I swear the N/A version did.
I used to install the earlier type cruise controls and they all used vacuum to run a throttle hold/pull/release cable .
I recall asking how the turbo ran cruise under boost and reply was electric vacuum pump on Libs. That my be the way to go. Can always do after market with cable throttles, fit your own electric vac pump. Try Command Auto Group for an application. In Botany, have developed heaps of CC's over the years and have good customer relations.
ahh, that makes a bit of sense now. At least there is some reason (Cost) for them not to put cruise into the GT's.steptoe wrote:I used to install the earlier type cruise controls and they all used vacuum to run a throttle hold/pull/release cable .
Damn the RS Libs came with a lot if good kit, water to air IC, hyrdrolic clutch, cruise etc. They must have cost a bit new.
I think that it is likely yes these older ones used vacuum and the turbos inlet manifold vacuum turns to pressure would upset the apple cart. If they are vacuum and you scored any after market or NA system you just need to supply the vacuum by another means and not even need a hook up to inlet at all
