Spidery (manifold) goodness -> issues++
Posted: Sun Mar 26, 2006 5:11 pm
Good to be back!
Been stuffing around troubleshooting these problems, and would value any opinions/suggestions from anyone who has been this dark path of sorrow previously...
have an EA82T L-seies conversion from an australian delivered donor car
Fitted a spider manifold with an RS IC and experienced issues since - mainly idle and fuel eccomony, BUT it goes much harder.
Issue 1: idle is rough & high despite modifications to TPS, hot/cold running etc. ECU consistantly shows no fault codes.
Issue 2: Ecomony - about 275km tank driving nice. Going hard about 250km with black gunge over the tailgate. This was an issue B4 the manifold was fitted, but not as bad. Std boost
Had injectors cleaned - very very gummed up (despite only using PULP). since cleaning car runs better, more power, but ecomony is unchanged.
Swapped both the AFM, dizzy & ECU with a RX that returns 12ish lt/100 - no difference !!
Sooo, given there has been much stuffing around trying to get this right, (thanks muchly to Steve B) was thinking a WOLF 3D would be way to go - any suggestions / tips / comments heading down this path?? Anything I've missed??
thanks[/u]
thanks[/u]
