head gasket
Libsta
head gasket
Post by Libsta » Wed Dec 01, 2010 5:34 pm
Hey guys.. ive come to the conclusion that ive blown a head gasket on my ej22.
It doesnt over heat as of yet... but the radiator overflow bottle keeps filling and overflowing... and also the inside of the radiator chamber is slightly milky (not much but its there)
Ive replaced the thermostat and seeing what happens from there but im pretty sure its the head gasket.
Where abouts can i get a new set of head gaskets in perth? last time i checked they were damn expensive...
It **sses me off because this is my 3rd engine within a year :(
1st was due to crank pulley stripped keyway and we welded it once then eventually gave way.
2nd was due to.. well not much in the end..
and now the 3rd is giving up on me :P
Well if any of the perth boys could help me out with the head gaskets that would be great :)
cheers
Bob
Post by AlpineRaven » Wed Dec 01, 2010 7:17 pm
Bit of a bad luck eh..
Thought EJ22 was tough engines shouldnt have H/G problems! In my memory for EJ25's headgasket aftermarket is around $80-$100 and should be the same price for EJ22.
Post by AndrewT » Wed Dec 01, 2010 7:48 pm
Cooling systems can be tricky to have bleed properly, could be an air pocket or other simple issue.
Before jumping to conclusions, get the head gasket idea confirmed by a TK test. Any radiator shop should be able to do it and actually confirm if you have a head gasket issue.
Libsta
Post by Libsta » Wed Dec 01, 2010 10:56 pm
True True... well ive spent an hour today at a radiator shop testing the rad cap and thermostat... so i might pop back in there and get him to do the TK Test to see what comes up... im guessing it is HG because i mean you have prob heard me on here going on about how gutless this ej22 is :P it would kind of make sense now
Post by TOONGA » Thu Dec 02, 2010 9:51 am
Libsta wrote: 2nd was due to.. well not much in the end..
cheers
Bob
Bob an intermittent crank rattle isn't a small thing :) or at least that what it sounds like.
have you checked under the oil cap thats a more reliable way of telling if the head gasket has failed
how long do you want to wait for this head gasket kit as Ebay US has some nice deals at the moment. (some include new head bolts as well)
http://motors.shop.ebay.com/i.html?_trk ... p=15&_sc=1
while the kits are cheap the shipping can look prohibitive, when you price a kit here and head bolts it still works out cheaper from the US.
as for quality isn't everything made in China these days :)
Libsta
Post by Libsta » Thu Dec 02, 2010 2:04 pm
Well ive got a hold of a new set for $50 :) so im going to just do the heads anyways
Post by TOONGA » Thu Dec 02, 2010 3:07 pm
Libsta wrote:Well ive got a hold of a new set for $50 :) so im going to just do the heads anyways
nice score Bob any more at that price Im sure people would line up for them
Libsta
Post by Libsta » Fri Dec 03, 2010 4:34 pm
Well america has a set of ALL top end gasket sets plus some little extras and also a set of head bolts for $150 posted :P
