Your Christmas wish list- Subaru based
Time for a little fun and get into the spirit of the season. Who knows, maybe the jolly fellow in the red suit might stumble upon this site for some ideas
Some simple guidelines- List three products you would like to find under your Christmas tree for your Subaru. No pie-in-the-sky items or things you can only dream to exist... Basically any product you can actually get a hold of in the foreseeable future, new or second hand.
I'll get the ball rolling with my top three, in no particular order:
-SubaXtreme Brumby bullbar
-Rigid Industries 20" LED light bar
-A nice sized Waeco or Engel fridge.
Your turn
Your turn
- subybrumby
1. A decent tune on an EA82T fitted with an EMS stinger ECU done here in Toowoomba
(That will happen I expect)
2. A decent drink holder that I can permanently fit in the cab that looks like it was custom made for the Brumby ute and not some cheap ass junk that fits on to an air vent.
3. A long range stainless fuel tank fitted underneath for a planned trip to Darwin next year. Sheet metal worker son to look at that. Got more wishes if you want to expaaannnd the number.
Have you had a look at the Gen2 Liberty pop out cup holder? It is DIN width, very slim and will take your can of coke/cup of coffee. 600ml bottles don't fit though...
Onto my wishlist:
1. My liscence back...
2. Gen1 dual range lib gearbox. Then i can think about building a magical centre locking, 4.44 ratio, 1.59 low range gearbox.
Onto my wishlist:
hey guys i thought i might just pop mine in :P
1. EJ22
2. LSD diff locker
3. kings springs, or something similar
i know i'm abit behind you guys but hey i'm getting there :P
1. EJ22
2. LSD diff locker
Dann
Looking for:
- LSD diff
Dann
Looking for:
- LSD diff
- Silverbullet
- d_generate
More than 8.5psi boost, hope the new V2 RA STI ECU will help.
1 more inch of lift.....coming soon
the 2 door rx i saw..........
so cheap, duel rage awd locking box, EA 82T factory intercooled
=D*****
but again i doubt ill get it, just want all my parts to come and to fix my honda so i can start building lisa
=D*****
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
1. New shocks and raised springs to go on the Outback.
2. Finish the RX
2. Finish the RX
Here is mine:D
-EJ25 single cam.....(Found A QUAD cam EJ25, soon to be mine:p)
-RXII Full Time 5spd D/R with diff lock Gearbox
-CLSD Diff (if I can find one)
-5stud conversion
-Forester rims (bought a set:p)
-All new bushes (front half already installed:p)
-New Front and rear suspension
-Replace heater core
-Better dual rear wheel carrier
-5stud conversion
I am giving my L the work it deserves for xmas
* Engine & Trans Mounts (Possibly drop my spare RX turbo box in too)
* All front end bushes
* Driveshafts
* Suspension bushes
* Timing belt
* Pull a dent out the passenger side door then repsray it
Things I want for xmas
* Webber
* One of the rare carbed EJ engines (I refuse to go EFI :P)
* Lowered Springs
* 5 Stud conversion kit
* Brembo rotors + pads
* Respray the car gun metal grey
* AWD Liberty/Rex Gearbox with adapter plate to suit the EA82
* Driveshafts
* Suspension bushes
* Timing belt
* Webber
* Lowered Springs
- TOONGA
well I got the gearbox but the scorpion low range gear set is not going to happen mind you it is a gen 1 series 1 box as I understand itTOONGA wrote:hmmmmm the dual range setup Ive been looking at down my way and a scorpion low range gearing to go in it
I may have to put a deposit on all the bits and hope santa can pay the rest for me
Just have to finish paying for it (Roll on Febuary)
Get an AWD EJ gearbox and an EA L series gearbox (both dual range or single range), split them and swap internals. There might need to be a dedent ball and spring added to the EA's box to hold low range in place when selected but its nothing serious.someguy wrote:* AWD Liberty/Rex Gearbox with adapter plate to suit the EA82
Use an L series low range. A little more mucking around but it is easily done - read up on Alpine Raven's write up about it. They're the same thing anyway, just that the L series one is already used...TOONGA wrote:well I got the gearbox but the scorpion low range gear set is not going to happen mind you it is a gen 1 series 1 box as I understand it
Hope this brings some xmas cheer!
Chrissy stocking filler
Well what I would like is a Brumby with a woman owner that wants to go camping with another Brumby and owner.
ehehehehe hohohohoho
Hylton:twisted:
Hylton:twisted:
