efi and carbi motors
- jollylseries
can anyone tell me if a carbi intake will fit on efi block and heads of an ea82 motors as i have got efi motor but carbi motor in car and dont want to put all the computer crap in or would i be better trying to put computer in for efi
First of all, punctuation is really important if you want other forum members to understand your post.
Im guessing that you have a blown carby motor in your car, and a good MPFI engine in your shed?
EA82 MPFI heads are slightly different to EA82 carby ones. MPFI heads have dual intake ports whereas the carby only has sinlge intake ports. Thus are not interchangeable
The blocks are close enough to be the same, the only difference being that MPFI blocks were 9.5:1 compression (carby was 9.0:1) and they have an extra crankcase vent near the bell housing.
Give us a little more detail and we will see if we can help you
- jollylseries
I too, was once a grammar nazi. Once I received text messages I realized that to the younger generation punctuation is as relevant as superannuation. If you can read text messages then anything is comprehensible. However, Suparoo's explanation of the extra crankcase vent on the EFI engine is probably the answer to my question about the capped pipe on the EA82 carby engine air cleaner. And to quote Clive James, " everyone wants to use the comma and the apostrophe but nobody knows where they go ".;)
Bad grammar is a pet hate of mine. It usually means one has to read the post several times just to get the gist of it
One full stop, 2 commas and 2 question marks.
Now back to your question...
You will need the motor and all associated sensors. This includes the air flow meter, distributor (being an Aus delivered MPFI, it will be a 4 plug system and thus have no vac advance on the dizzy)
You will need the wiring loom and ECU
You will then need the EFI fuel pump, fuel tank and preferably the return line as well.
Its quite a big job.
What is wrong with your current motor?
Thanks for that. Well if thats the case, how hard is it to wire the mpfi motor in? Much work in it, or prety easy to do?jollylseries wrote:thanks for that well if thats the case how hard is it to wire the mpfi motor in much work in it or prety easy to do
- jollylseries
- TOONGA
ouch!Suparoo wrote:Bad grammar is a pet hate of mine. It usually means one has to read the post several times just to get the gist of it
If you going to the trouble of changing from a carby engined ea82 to an MPFI engine, you may as well go the whole hog and plunge into an EJ computer controled motor. Either that or go the carbied EJ motor, like I did.jollylseries wrote:current motor has a few oil leaks, starting to blow smoke and has lifter noise and was hopping it would be an easy change over but its not looking like it so where would be the best place to look for another ea82 carbi motor
You could put the carby heads on the MPFI block, this would gain you a bit of extra compression.
Or if you are feeling adventurous, take the throttle body off the MPFI plenum, make an alloy adapter plate and bolt a weber onto it.
- jollylseries
maybe ill stick up for the little guy here
punctuation and spelling arent my strong points and the oldies here (XD) like to have a dig every time they get the chance
the motors are the same but different
if you want to do the change quick get another carb motor, they go forever and engine out in and running can be done in 2.5 hours if your good
MPFI engines make a little more power but the swap can be a little harder. if you want the power and your car is alright now you can shorten the wiring loom so it only runs the engine and place it in the engine bay or somwhere close without having to run the loom to everything else.
this means that you will be able to do the swap a little faster, the wiring is the hardest part though
if im needed for anything spike.pickstock.racing@hotmail.com and ill try and get back to you.
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
