STI gearbox
- velocityboy
STI gearbox
[img][IMG]http://img593.imageshack.us/img593/3533/dsc09877.jpg[/img][/IMG]Just haveing a look at the motor and box that I'm putting in my Brumby and noticed the auto box has a STI logo on the side of it. Dose that mean anything or are all these boxes marked STI? This is out of a 1991 RS GT liberty.
If you get the serial number, i'm sure someone will be able to tell you what the box came out of.
- T'subaru
not to much on StI auto trannys here, check this out.
http://www.autoblog.com/2010/07/07/suba ... own-under/
I had a gearbox (with engine) that had the same thing on it.. didn't see any difference in it and it came from a JDM GT Foz. It went into a WRX without any issues.. just needed to match the rear diff to the ratios.
That's true in Aus but Japan has had auto STi cars for many years.Subafury wrote:im 90% sure the first sti to come with an auto box is the current MY11. so no it will not be an sti one.
- velocityboy
Yepguyph_01 wrote:If you get the serial number, i'm sure someone will be able to tell you what the box came out of.
velocityboy.. if you google the number (should start with TZ...) on the sticker next to where the starter motor, you should find some good info on it
