ej25 out of 98 outback
shuffbag
Post by shuffbag » Fri Jun 03, 2011 11:14 am
would a ej25 out of a 98 out back have security gear from factory? Trying to find out how hard the loom strip will be.
Can anyone throw me a link to a ecu pin out please? Its auto if that matters?
Post by guyph_01 » Fri Jun 03, 2011 11:59 am
Pack it all up and send it to Subarino:p
I must say he did a great job with mine. From the 60cm square box compact of wiring i sent him, only a 20cm square box of engine loom came back all labeled.
d_generate
Post by d_generate » Fri Jun 03, 2011 5:01 pm
Notoriously bad engine for head gaskets blowing, if they haven't been done yet it would be worth changing them while the motor is out, otherwise a great motor.
Post by Gannon » Fri Jun 03, 2011 5:11 pm
Yes you will need to retain the security/immobiliser wiring for it to work. This includes the coded key and ignition barrel with the antenna ring around it and the immobiliser box. Other i think there are only 2 or so wires from the immobiliser box to the ECU
shuffbag
Post by shuffbag » Fri Jun 03, 2011 7:03 pm
i have full wiring but no keys or ing. my wifes forester of the same year doesnt have an immobiliser?
the ecu has a 21 sticker.
i did my last loom for a ej swap, so i will be doing this aswell.
i guess if there is no way around the immobiliser (if it has it) i'll build a franken motor i belive they run the ej22 looms.
what would be a dead give away of an immobiliser (loom specific)? i'll post up a pick of the loom if it helps?
Post by Gannon » Fri Jun 03, 2011 7:29 pm
immobiliser plug is a 12pin 2 row plug.
FROG
Post by FROG » Fri Jun 03, 2011 7:40 pm
Pm me the donor vin and I'll see what it says
shuffbag
Post by shuffbag » Sat Jun 04, 2011 12:04 am
sorry frog unless there is something on the engine or box im out of luck, all i know is it was a 98 bg9 outback
Post by Gannon » Sat Jun 04, 2011 7:44 am
Ok so BG means it is from a Gen2 (1993-1998 )
It does not have an immobiliser so you have nothing to worry about
A quick rundown of model codes for sedan and wagon Liberty's
BC/BF is Gen1
BD/BG is Gen2
BE/BH is Gen3
BL/BP is Gen4
shuffbag
Post by shuffbag » Sat Jun 04, 2011 4:26 pm
yes yes yes yes! i thought so but wasnt sure, but still i cant find a pin out for the ecu (googling all night).... anyone? almost died when my mate looked up the prices for gaskets.
Post by TOONGA » Sat Jun 04, 2011 4:48 pm
SuBaRiNo
Post by SuBaRiNo » Sat Jun 04, 2011 4:57 pm
Good luck finding a wiring diagram.. I have done a few ej25 harnesses and non matched the ones I found online.. Ended up having to do them my feel.
Dave
shuffbag
Post by shuffbag » Sat Jun 04, 2011 5:39 pm
thanks toonga that helped alot, i hear bad things about ebay gaskets. just realized im missing extra electrical gear :(
ignighter and afm (unless a ej22 one works, i have one and the plug is the same), are there any other bits i might have over looked? i have full wiring,ecu and a ej22 afm
i wired my mates sr20 the other week and that was nothing compaired to subaru stuff!
