Page 1 of 2
rear shock help?
Posted: Fri Jul 08, 2011 6:26 pm
by thelman
ok, so today i went to put the honda springs in the back of rupert. Trouble is, i cant get the nuts off the top. The shock is turning when i turn the nut. Ive tried all i can think of and no dice. Anyone got any ideas?
Posted: Fri Jul 08, 2011 6:33 pm
Ok, to remove the springs from the L shock you need to have the spring compressed enough so that there is no compression on the "top hat" of the spring.
Then use a shifter to hold the flat part at the top of the shock's rod above the thread. Then get your appropriately sized spanner or ring spanner and go from there. This is how it worked for me.
If it's the honda strut, do the same to the spring in terms of compression. You need a hex or allen key for the top of the strut's rod to hold it still. Again use an appropriately sized spanner or ring spanner and you should be in business.
Posted: Fri Jul 08, 2011 6:35 pm
by sven '2'
thelman wrote:ok, so today i went to put the honda springs in the back of rupert. Trouble is, i cant get the nuts off the top. The shock is turning when i turn the nut. Ive tried all i can think of and no dice. Anyone got any ideas?
You have a spring compressor in place i trust!
Use strap wrench on the piston, even an old leather belt will do.
If you must multigrips, be sure to grip the shaft well above the travel range, or you will chop out the seals
Posted: Fri Jul 08, 2011 6:45 pm
by thelman
yes have compressors on, not silly lol. There was no pressure on the top, but the flat broke off the top. Will try the strap as suggested by sven
Posted: Sat Jul 09, 2011 12:03 am
by sven '2'
Good to hear - was not having a go, not mentioned in your OP, and well, stranger things have happened!
Posted: Sat Jul 09, 2011 1:21 pm
by thelman
still no f¤$£ing go. Anyone wana cum do it?
Posted: Sat Jul 09, 2011 2:08 pm
by MTB92
mine was just a lock nut arangement on the rear. 2 nuts, undo the top one, do up the bottom one and they seperate and can unscrew by hand from there. never had to go near the flat bit at the top. not the same?
Posted: Sat Jul 09, 2011 7:09 pm
by thelman
screw it. Im goin to u pull it!
Posted: Sat Jul 09, 2011 7:41 pm
by TOONGA
thelman wrote:screw it. Im goin to u pull it!
thats a better idea the only other thing I would have suggested was using a file or a grinder to make a new flat section on the thread above the bolt
Posted: Sat Jul 09, 2011 11:31 pm
I think someone's itching to have some new rear springs :rolleyes:
How'd you go with this?
Posted: Sun Jul 10, 2011 12:44 am
by thelman
will let u all know tomorrow after ive been and had a crack
Posted: Sun Jul 10, 2011 7:05 am
by sven '2'
thelman wrote:still no f¤$£ing go. Anyone wana cum do it?
What is your 20 and is there beer involved?!
Posted: Sun Jul 10, 2011 2:04 pm
by thelman
ok, springs are in. Bonus, adjustable collar shocks! While i was there, i picked up an air strut for the liberty to replace the one i know is stuffed
Posted: Mon Jul 11, 2011 3:15 am
Good stuff! Easy mod eh?
How do you find the ride with the springs a little stiffer?
Posted: Tue Jul 12, 2011 12:09 am
by thelman
easy mod bennie. Only hard part was compressing the honda springs. Could have been easier with a modified set of compressors. The ride is gret, i just need to lift the front a bit more now
Posted: Tue Jul 12, 2011 7:40 am
by skrewd
iv just done the front of mine with front springs out of an ea falcon, i have been meaning to do a wrie up about em but still not 100% sure on them....it might sound to you's that they would be to stiff for a subie but you would be very surprised at the outcome...will let you all know very soon....
Posted: Tue Jul 12, 2011 9:01 am
Falcon 'ell EA springs!! I would expect them to be rock hard in a lightweight subie
Posted: Tue Jul 12, 2011 5:24 pm
by skrewd
steptoe wrote:Falcon 'ell EA springs!! I would expect them to be rock hard in a lightweight subie
yeh they where pretty knacked when they come out of the ford and i had my doubts to, but they are the same diamater give or take an mil or two and had a cpl of spare hrs so thought why not....they are stiff but there no where near as stiff as you would think. iv been up the bush for a run with them and im very happy with the way it went on the day. i was with guys with lifted landcruisers and patrols and as always the subie showed em up....:mrgreen:
Posted: Tue Jul 12, 2011 6:16 pm
by thelman
cmon, do the write up. How much did it lift it? I picked up some adjustable front shocks off an older L today
Posted: Tue Jul 12, 2011 7:20 pm
by skrewd
thelman wrote:cmon, do the write up. How much did it lift it? I picked up some adjustable front shocks off an older L today
yeh sorry i shouldve mentioned the lift part of it. i got about an inch lift out of it and i have full lock both ways without scrubbing, its only got 2inch body lift and havnt trimmed the guards but im still not 100% sure about them thats why i havnt put up pics or done a write up
