help on ej20 conversion for subaru brumby
namhit
Post by namhit » Mon Aug 08, 2011 9:53 am
hi i own a 92 subaru brumby, and want to put an ej20 into to it non turbo as i am still a p plater. dont have much experience in doing this so would like to know if theirs mechanics that will do this for me.
and also what parts do i need to get and change for this im on my way of getting an ej20 with gear box soon.
if any one can help would be really good thanks :)
Venom
Post by Venom » Mon Aug 08, 2011 10:17 am
If you're in QLD and you're going to pay for a conversion then i think AMauto is the place to go. They make a living doing engine conversions and they have an excellent reputation. Al is a no bullshit person, he'll tell you what you need and be honest about the price.
Basically you need the motor, engine wiring loom and ECU. you'll need an adapter plate to mate the EJ motor to your standard gearbox.
namhit
Post by namhit » Mon Aug 08, 2011 12:45 pm
thanks heaps. man :)
Post by El_Freddo » Mon Aug 08, 2011 3:38 pm
And do some searching on the forum, there are plenty of threads out there about the EJ22 conversion that would apply to your EJ20 conversion - a couple of aspects that will be different but you'll get the general picture ;)
gosurfun
Post by gosurfun » Tue Aug 09, 2011 2:49 pm
From my limited knowledge stick with a manual drive train, the auto will only fit with a lot of body work (time and $). Use a SOHC motor (EJ20 or EJ22) (DOHC are wider, same block, bigger heads) then the chassis rails do not need to be cut for the motor to fit, less work and $ for engineers etc, check it with a tape measure and previous swaps done here and elsewhere! If you want to turbo it later on the subaru turbo manifolds fit it as well, it will need turbo pistons, bottom end work, different ECU etc if running above 5-7 psi. The SOHC can still make a lot of power if turbo'd, it is not essential to use a DOHC WRX motor. The later EJ20 N/A makes more power than the original 2 litre turbo's did. The Brumby is lighter than a WRX so in theory, N/A 110 kw in your 1000 kg Brumby will be equivalent to turbo'd 150 kw in a 1400 kg WRX.
Changing to a stronger gearbox may change the front drive ratio, so check what it is first and price a rear diff in if needed. The gearbox change will most likely need a new or modded tailshaft, possibly an adapter plate and clutch as well. It depends on the combination of parts you pick.
There is plenty of stuff here and in other forums on this swap, the hardest part is deciding which is the best combination for what you want to do now and possibly later on. There is a lot of help in here and other forums, but it can take a lot of time reading on the net. Reading now is much cheaper and less work than doing the wrong swap.
Post by TOONGA » Tue Aug 09, 2011 5:44 pm
read this it will give you an insight in to the work that needs to be done
http://offroadingsubarus.com/downloads/EA2EJ.pdf
stolen from offroadingsubarus.com of course :)
Post by El_Freddo » Wed Aug 10, 2011 5:41 am
TOONGA wrote: stolen from offroadingsubarus.com of course :)
Not stolen - shared without them knowing yet... :D
