82 leone coupe side window seal replacement?
Been trying to research a replacement for the rubber seal between the side windows on the leone coupe. Mine are rock hard and already split in two. i've found a couple of threads around the web on this topic but nothing certain, and not in aussie land. Has someone solved this before? got two weeks to do it and in a different state than the car for most of it
Rhys
Sent from my GT-I9100T using Tapatalk
Rhys
Is that a similiar seal to the MY Wagon rear window? If it is you can buy a seal suitable from Clark rubber (usually have to order it in) or Novus (again may have to order it in) part number i think is W01.
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc. Offically now part of the 350, 000 km Club! And still pulling like a freight train.
"Claudia"
"Claudia"
Hi
This company sells it as a replacement for camaros etc they do fit
http://www.jcwhitney.com/quarter-window ... 08656.jcwx
Cheers Pete
Cheers Pete
Use The Fork Luke
Coupe Rubber
I got some from Subaru around 4 years ago, still had them in stock. I tried all the other rubber replacemnt places with no luck. they were reasonably prices from the factory.
+1.. I did the same not so long agolegacytt wrote:I got some from Subaru around 4 years ago, still had them in stock. I tried all the other rubber replacemnt places with no luck. they were reasonably prices from the factory.
