Snorkel
nope,
its basically a DIY
some people have purchased other snorkels and adapted them to fit,
i got mine made a my local exhaust shop out of 2.5" mid steel,
then i got it powdercoated.
i have the profile for cutting the hole into the fender if you'd like it?
its basically a DIY
"SUUBMARINE"
20" LED Front Light Bar
- d_generate
Hey Longy, 2.5" is pretty restrictive for a GT because of drag on the air by the time it gets to the turbo, I'd be going at least 3" - 3.5" to let it breathe, fine for a n/a though.
Seagull did some research on it and is going to ditch the new factory one from his Patrol and go 4" all the way because he's turbo'd it, needs to be bigger than the exhaust.
surely 2.5" cant be any smaller than the stock design anyway?
altho i do hear it really sucking in the air and whistling when i firmly accelerate
i stuck with 2.5" at the time as it didnt stick out past the fender
(in case cops were being fussy)
Not sure what i'll do with my next forester i get, whether i make one again, or not
main advantage is a cleaner air intake and no water ingress (if sealed correctly)
but turbo's probly dont help it.....
ohwell
ohwell
"SUUBMARINE"
- d_generate
It's the length of the pipe that also slows it down, even the standard air box is 80mm going to the turbo, you wouldn't notice it below probably 3,500 but it would be like trying to breathe through a piece of garden hose after you just ran around the block, fine when at rest but not so good otherwise, can you disconnect it temporarily to see if there is a difference because I'm sure you'd be down 10-20% on power up top and probably using more fuel too.longy99gt wrote:surely 2.5" cant be any smaller than the stock design anyway?
ohwell
The first thing most people do with a turbo is put as little restriction as possible with a short fat intake and pod, I don't like pods so on my Liberty I've got a 90mm pipe going to my air box from the cool air at the bottom of the inner guard and a much thicker pipe going from the AFM to the turbo, it's worth about 15-20hp.
On the offroader I've just got a standard Gen 2 Liberty air box open to the inner guard but I don't intend doing any deep water crossings either and if I was to put an open flow rear muffler on the back as it's 3" from the turbo back to the very restrictive standard WRX muffler I'd probably gain another 10hp, it's all about getting lots of cool air in and out of turbo's that make them so good......Hence front mounts and water sprays on intercoolers etc.
