no spark
Posted: Mon May 14, 2012 7:32 pm
by joffa81
hi everyone, was driving the brumby last week heading home it started to coff n splutter alot would stall at intersections. later that day would not start at all its getting plenty of fuel but no spark. i did replace the coil and everything is wired up correctly still no go......
I have read a fair bit about the ignition module in the elec dizzy could this be rooted hence no spark. its a 90 brumby if that helps..
Posted: Mon May 14, 2012 7:40 pm
by AshR
I'm not totally mechanical but checked battery too?
Then trace back to alternation that may have kicked the bucket... (I could be way off the mark, but being electrical like you suggest start at one end and work through to the other)
Posted: Mon May 14, 2012 10:03 pm
by joffa81
battery, alt all good did kick over a couple of times but would never rev over 2000 and alot of black smoke sounded like running on one cylinder
Posted: Mon May 14, 2012 10:18 pm
Replace that little module, it'll fire up first kick of the starter motor.
This thread has the list of vehicle make and models that use the same module
Posted: Mon May 14, 2012 11:09 pm
Ive had modules die on me twice now, they both died , no spark meant no idle or just under 2000rpm. The first dead module got tricked back into life just enough to get home - avoiding a tow. Got tricked by my spark test tool somehow and roared into life. the second one, just sput, died, never to go again
Posted: Tue May 15, 2012 12:39 am
by RSR 555
Ok.. lets start from the top..
Did you replace anything before you started having the troubles?
Did you wash the engine bay with water at any stage? (please check under cap for moisture)
Did you replace the coil with the one to match your dizzy?
Please take a pic of the coil (and wiring) and post up.
