power steering brake down
Posted: Mon Jan 07, 2013 12:08 pm
by phillatdarwin
hi all i looking for a power steering brake down diagram so i can reseal the one i going to put in my car after i get it rego this week it been off the road for some time got engine transplant and the power steering rack i got leaking ...
Posted: Mon Jan 07, 2013 12:09 pm
by phillatdarwin
phillatdarwin wrote:hi all i looking for a power steering brake down diagram so i can reseal the one i going to put in my car after i get it rego this week it been off the road for some time got engine transplant and the power steering rack i got leaking ...
my can is a 93 L
Posted: Mon Jan 07, 2013 12:12 pm
Phil, have you tried the Lucas power steering leak fix stuff made in USA about 14 bucks at Super cheap, have used many times on some weird leaks like when it sits unused it nearly poured out. I think my L is half PS fluid half Lucas now :D
Being 93 would be the later pump - I only have for early pump.
Does your subie dealer still have the parts books to refer to ? Their parts are best and not so dear. And if you ask nicely may get a pic copy of diagram you need
Posted: Mon Jan 07, 2013 6:38 pm
by littlewhiteute
Breakdown not brake down.
Power steering racks are not for novices.
Posted: Mon Jan 07, 2013 9:49 pm
Now you tell us :( , think I have one coming from the US ..... a kit, not the steering rack itself - unless it came with all the other bits to do a LHD conversion :D
Posted: Tue Jan 08, 2013 11:34 am
by RSR 555
littlewhiteute wrote:Power steering racks are not for novices.
+1.. They are a tricky to setup correctly.. get it wrong and it could lock up on ya :(
Posted: Wed Jan 09, 2013 5:32 am
by d_generate
Put a "cap" (not cup) full of brake fluid in the reservoir, this will make the seals swell and usually stops leaks for quite a while, drive the car for a while after/if you do it.
Posted: Fri Jan 11, 2013 11:22 am
by phillatdarwin
thanks all for the replys
ya will try it all as the car the rack come out of was sitting for some years .. ya seals are leaking just wanted to replace all seals on the end of rack and input ..
Ya i can see the dealer hear as i know one of the guys well in spear parts will look into it ..
Posted: Wed Feb 13, 2013 10:09 am
by AlpineRaven
d_generate wrote:Put a "cap" (not cup) full of brake fluid in the reservoir, this will make the seals swell and usually stops leaks for quite a while, drive the car for a while after/if you do it.
I second that - Ive done that in a few cars and it does help.
Normally its a cap of fluid from the bottle's lid, or same size cap as your engine oil cup - thats about enough for it, i've done two caps and doesn't hurt. As far I know it lasts for a while - as far I know a while as never did the seals on the power steering as it helped.
