Pretty trivial, but what do you guys use for engine cleaning?
G'day all, my donk is looking a little dirty [a fair bit of residual oil, but no major leaks] - so to give her a freshen up - what type of cleaning product / degreaser do you recommend? I've used a couple of brands in the past on some old bangers with mixed success, but nothing on the Foz. Any tips / suggestions will be greatly appreciated, cheers Peter
Be careful where you wet because although most engine sensors are pretty water resistant when the car leaves the factory, constant heating/ cooling cycles weakens their seals. Be careful around the knock sensor, coil pack and throttle sensor.
Usually just spray the oily areas with foaming degreaser, let it sit for a while and spray off with a hose. Pressure cleaners are generally not recommended because they can force water through rubber seals
The Export spray degreaser is surprisingly good, and with it you can get the stuff right where you want it. Picked up a couple of cans for $1 each on sale not too long ago.steptoe wrote:from within the automotive trade the advice is don't, on anything efi.
I love SCA export degreaser in the spray cans. Wax and grease remover is good on a rag -wipe,wipe and my favourite is the wire brush on a rotary tool
I'm happy to give my EFI engine a good clean but there's a few rules I stick to:
*Never use the high pressure hose anywhere inside the engine bay.
*Keep away from alternator, coil pack, spark plugs, electrical connectors, sensors, fuse box & esp the ECU (mine is on the engine)
*Use degreaser 1st.
*Then use low pressure soap.
*Then low pressure rinse.
*Have a coldie
*Use degreaser 1st.
*Have a coldie
