Pretty trivial, but what do you guys use for engine cleaning?
Posted: Tue May 14, 2013 2:05 pm
by dyrgutt
G'day all, my donk is looking a little dirty [a fair bit of residual oil, but no major leaks] - so to give her a freshen up - what type of cleaning product / degreaser do you recommend? I've used a couple of brands in the past on some old bangers with mixed success, but nothing on the Foz. Any tips / suggestions will be greatly appreciated, cheers Peter
Posted: Tue May 14, 2013 3:00 pm
by Gannon
Be careful where you wet because although most engine sensors are pretty water resistant when the car leaves the factory, constant heating/ cooling cycles weakens their seals. Be careful around the knock sensor, coil pack and throttle sensor.
Usually just spray the oily areas with foaming degreaser, let it sit for a while and spray off with a hose. Pressure cleaners are generally not recommended because they can force water through rubber seals
Posted: Tue May 14, 2013 3:22 pm
by Esubie
Home Brand (generic) Oven Cleaner ?
Posted: Tue May 14, 2013 3:24 pm
by Cliff R
Sorry, the following may not be very helpful but the MY with its EA81 engine has no sensors so I use the nastiest stuff I can find which is the degreaser from Reject Shop for $2 a can and the engine cops it.
Not for too long though as I think it may take the paint off.
Posted: Tue May 14, 2013 3:31 pm
by lupin
I've had a fair bit of success with a few liquid ones and brushing it on, letting it settle the brushing / wiping it off with a rag.
Currently using a chemtech one. CT14 from memory.
Posted: Tue May 14, 2013 4:38 pm
from within the automotive trade the advice is don't, on anything efi.
I love SCA export degreaser in the spray cans. Wax and grease remover is good on a rag -wipe,wipe and my favourite is the wire brush on a rotary tool
Posted: Tue May 14, 2013 5:57 pm
by Tweety
some stuff does nasty things to the alloy as I found out. I will stick with the degreaser spray can from now on.
Posted: Wed May 15, 2013 11:48 am
by Davidov
steptoe wrote:from within the automotive trade the advice is don't, on anything efi.
The Export spray degreaser is surprisingly good, and with it you can get the stuff right where you want it. Picked up a couple of cans for $1 each on sale not too long ago.
Posted: Wed May 15, 2013 6:46 pm
by TOONGA
I did have some CT/14 but sadly that came to an end
great stuff but it will make polished aluminium pearl finish.
Posted: Wed May 15, 2013 7:36 pm
by NachaLuva
I'm happy to give my EFI engine a good clean but there's a few rules I stick to:
*Never use the high pressure hose anywhere inside the engine bay.
*Keep away from alternator, coil pack, spark plugs, electrical connectors, sensors, fuse box & esp the ECU (mine is on the engine)
*Use degreaser 1st.
*Then use low pressure soap.
*Then low pressure rinse.
*Have a coldie
Posted: Thu May 16, 2013 10:53 pm
by dyrgutt
cheers for all the advice guys - I went with a watered down blend and opted for a bit more manual labour, just to be safe - good thing, too - for I found a couple of things that needed amending along the way...so thanks again
