ABS light on, please help!
sedanmike
Post by sedanmike » Tue Nov 26, 2013 7:46 pm
My Abs light stays on all the time on my 1999 Legacy outback (import). I have checked the fuse box inside the car, I have cleaned the wheel speed sensors. I have also done the diagnostic with the black connector and the light still stays on permanently. I did read on the web somewhere that some people take the fuse out under the hood to turn off the abs and this makes the light stay on permanently but I can't find the fuse/relay. Has anyone got any ideas?
Please help, I bought the car recently and are trying to get it ready for the RWC and this is holding me up.
Cheers mike
justincase41
Post by justincase41 » Tue Nov 26, 2013 8:40 pm
What fault code does the diagnostic scanner show? Make sure that your scanner actually does the ABS as some of the cheaper diagnostic scanners don't.
Current :
1992 Brumby (Future EJ20 Conversion)
2007 Toyota Prado 120
2012 Great Wall V200 (daily driver)
1997 Subaru Outback
1999 Toyota Surf (Beach Basher)
Past:
To Many to list!
sedanmike
Post by sedanmike » Tue Nov 26, 2013 8:44 pm
justincase41 wrote:What fault code does the diagnostic scanner show? Make sure that your scanner actually does the ABS as some of the cheaper diagnostic scanners don't.
The scanner I have doesn't scan abs codes so I did the flashing light check with the two prongs in the black connector.
Thanks
Kustomchris
Post by Kustomchris » Tue Nov 26, 2013 11:05 pm
Blown brake light globe?
Maybe the globes fitted are not providing enough resistance?
Kustomchris
Post by Kustomchris » Wed Nov 27, 2013 12:26 am
Also check out the wiring for your trailer plug as well
sedanmike
Post by sedanmike » Wed Nov 27, 2013 11:08 pm
Never thought of checking tow bar. It all looks normal. Does anyone know if there is a relay somewhere?
Thanks
Mike
Post by RSR 555 » Thu Nov 28, 2013 12:07 am
Hey Mike,
I have a 2000 model H6 Outback that has the ABS light and Check Engine light turn off once you start the engine but as soon as you drive the car 10 metres, they both come on. I've had it on the scanner and all sensors and ABS motors are working fine. I'd like to know if you solve this and like wise, I'll let you know if I find what fixes mine.
Paul
Kustomchris
Post by Kustomchris » Thu Nov 28, 2013 2:48 am
sedanmike wrote:Never thought of checking tow bar. It all looks normal. Does anyone know if there is a relay somewhere?
Thanks
Mike
Trailer plug is just a wild guess, i know that led tailights on trailers can bring up this error if you dont have a resistor fitted in the line.
Another idea is that maybe the globes in the tail lights arent bright enough/ providing enough resistance in the line.
