ej22 into Brumby
ej22 into Brumby
Hi everyone out there in Subaru land
I've got a 88 Brumby that I had been doing all sorts of homework on replacing the ever tiring ea81, whether to rebuild ,put in a ea81T or something else altogether.So I decided to do something different altogether.I bought a wrecked 93 Liberty and pulled out the ej22 to put in the brumby I've also got a L series 5 speed to marry to it. If anyone has any helpful hints or threads on similar work you guys & girls may have carried out, this would be greatly appreciated, I know mechawagon had some great step by step instructions that he had on the old site that I was following carefully that fortuneately I saved the thread before the collapse of the site,but curious if he has any updates on his progress?
Regards Cheffy
Regards Cheffy
Good luck Cheffy, I have done something very similar...
http://www.ultimatesubaru.net/forum/sho ... hp?t=39822
I am rapt with my end result.
Matt
Matt
1989 Subaru WonderBrumby II
- Outback bloke
Just a bit of curiousity here but why do people want to mate the EJ series of motor to EA series gearboxes? We have done plenty of conversions and the EJ box is not a doubt when the conversion is being done. They mate to motor as they are meant to and there is not really any great troubles in making linkages work.
- BaronVonChickenPants
- Outback bloke
I was thinking that the tail shaft may be an issue but when you consider the cost of an adapter plate for an EA box they sort of cancel each other out in the $$ comparison. Add to that the issue of the width of the adapter and you have mounting issues which in comparison to the EJ box would be similar.
Brett,
I think most of us who fit into the "want to fit 5spd L series onto EJ engine" believe the gearbox to be better than the AWD gearboxes for some of the more hardcore 4x4'ing. Is also more suited to handling a welded rear diff.
When I get around to doing my ej18 I'll be doing the L series gearbox for that very reason.
However I also have the opposite situation, I want to hook up a AWD EJ box to my EA81-T eventually
- hatchback88
I agree with Hatchback and Stinky.
Another reason i did it is... the L box JUST fits in my hatch with a 3 inch lift kit. When i say JUST fits i mean... i had to physically cut the gear box to get it to fit... don't ask me why this had to be done. I assume the EJ boxes are bigger... if even 5mm bigger... it would not fit in my car without a bigger lift kit.
Another reason is i could use the same tail shaft, linkages, gear box mounts, rear diff... etc etc. When comparing the costs of them with an adapter plate and flywheel that can be easily modified and built yourself it is by far the cheepest option when doing an EJ conversion. cost me less than $100 for the adpter plate ally and a second hand flywheel and half a day making/modifying.
Sorry to ramble.
Dave
Sorry to ramble.
Dave
- Outback bloke
It is interesting to hear how and why other members do their conversions. I don't hesitate to use the EJ box with the viscous centre. I have never had a problem with it slipping between front and back at all. I do recognise that people are wanting the lower ratio low range though. Understandable.
The lower ratio swap has always had me wondering with the EJ boxes and the recent spate of breaking boxes between mine and Subamans has given us the opportunity to look in to it at greater lengths. It turns out that the low range swap is actually pretty straight forward using parts from a low ratio L box combined with the Liberty internals. All of which can be done with basic hand tools. No pressing is necessary.
We have nearly got all the parts we need to fix the broken bits. Once we get them Grant and I are going to take plenty of pics and do a write up for the board on both swaps.
I think these boxes are going to become a very popular option as the cost won't be much at all. While we were looking at the low ratio swap we also found out that a lower diff ratio is a very simple swap as well. Probably easier than the low ratio swap.
Doing the diff swap in an L box is also doable but does require a fair bit more work. Involves pressing.
- tim_81coupe
How is this done may I ask? Obviously you'll be using a different ring gear, but from what? I thought the rear differential was incompatible.byb555 wrote:While we were looking at the low ratio swap we also found out that a lower diff ratio is a very simple swap as well. Probably easier than the low ratio swap.
By the same token how hard is it to install a front LSD?
I might not be making sense here, I've never pulled apart an EJ gearbox, only 1 EA 4spd box and I was never going to put that back together...
With out giving away to many secrets, you can use either the 3.9, the 4.11 or the 4.444 diff , the rear must be changed to suit ofcourse. I too have an EJ22 into Brumby conversion about to happen but am going to be fitting an L Series AWD box with the manual locking centre diff, best of both worlds that way. The L Series and Liberty boxes are the same size so there is no problems there however there is a slight difference in length of the bellhousing on the box itself so the flywheel may need to be spaced to suit. As for the front wheel drive box, I just couldnt go back to all that torque steer and crap that the EJ is going to create as a front wheel drive.. CV`s wouldnt last an outing with a welded diff in a car like Bretts Lib with a 2.5 turbo and 29inch tyres, and I think you guys will find them an issue too once the EJ conversion is done.
Grant
Grant
- Ben
Brett, I chose using the L series box purely on an upfront cost basis, and very close behind that is the low range issue.
However, I recognise that to get my car to where I want to I am going to have to spend money in the future - but thats ok, because its money I haven't already spent getting a lib box into my car.
When the time comes I'll be looking for a D/R Constant AWD box with 1.596 low, 3.545 first gear and 4.44 diffs. Is this a possible box to build?
To fit an auto as I want the cost will be prohibitive, several times more than the cost of building a sweet 5 speed anyway.
Oh yeah, for all those contemplating ej's into L's with the standard box - in 2wd my car can easily get smoke off the BFG 27's on a dry road - it's insane, esp as I have 3.7 diffs too - in all the worst combination for turning big tyres...
- Outback bloke
