ej22 into Brumby
BaronVonChickenPants
Post by BaronVonChickenPants » Tue Oct 25, 2005 6:27 pm
I believe I read that some of the EJ DOJ's fit on the MY and L series shafts, also that the L series turbo automatic cv will fit directly onto the 25 spline EJ boxes.
So if your converting into an L series you can try to find some turbo shafts and you should be right, if your converting into an MY you can either adapt the EJ DOJ onto the MY shaft or adapt the MY outer cv joint onto the L series turbo shaft.
OR if your really lucky you'll find and EJ box with 23 spline axle stubs and the stock MY and L series DOJ's go straight on.
Jordan.
Outback bloke
Post by Outback bloke » Tue Oct 25, 2005 7:55 pm
4wd EJ inner cups are the same size as the EA inner cups but have the correct splines. Easiest fix around.
