Quick question - short drive in EA82 with low oil - damage?
Car has been sitting in a shed for 12 months and most of the oil must have leaked out. I took it for a short drive (maybe 5km) stupidly without checking the oil level and when I got home and checked it, it was only visible on the end of the dipstick, just shy of the "L" (low) indicator line.
Will I have likely done any damage to the engine??
Most dick sticks only show shy of about the top 1500ml of oil due to a human failing coz if we saw oil on stick that went right to the sump plug level some engines would die sooner.
You probably had 3.0 litres of oil if it was just showing.
First sign of not enough oil should be hydraulic lifters rattling their little insides out in protest. reckon you will be fine fishboy.
Most oil lights will only glow when you don't have enough oil pressure - think it is as low as 6psi on many cars !
Or, if you buy one of those twin turbo Bimmers, no dipstick at all ! The dash has an oil level indickator !
- Silverbullet
I always thought just having an oil warning light without a pressure gauge was a bit pointless, only telling you about the low oil situation when it's too late. Basically if the light comes on you have to turn the engine off immediately or cook the bearingssteptoe wrote: Most oil lights will only glow when you don't have enough oil pressure - think it is as low as 6psi on many cars !
Exactly.. the EA82 will let you know if there is not enough oil.. long before the low oil pressure light will show.steptoe wrote:First sign of not enough oil should be hydraulic lifters rattling their little insides out in protest. reckon you will be fine fishboy.
If your engine ran fine and didn't sound like a Massey Ferguson diesel tractor, then I reckon you'll be ok. Just give it an 'engine oil flush' and then change filter and oil, you should be good for another 20 years
