wind comming in front windows series 1 lib
Posted: Thu Jun 01, 2006 3:40 pm
by cruzingbrumby
My liberty when upto speed on the highway has an annoying whistle from both front windows when they are fully closed, where it seems air is comming in from outside. The car never leaks water or anything like that but wondering what the noise is from and if replacing the window rubber will fix it.
Any ideas, or same experience
Posted: Thu Jun 01, 2006 9:33 pm
by Oversteer
The piece the mirror bolts onto needs adjusting(remove trim, then loosen 2-3 bolts...)
..or you could use the subaru dealer prefered method of grabbing it and yanking it till it bends a bit...
OS
Posted: Thu Jun 01, 2006 10:32 pm
by milotin
I have 2 complete window rubber set ups for sale its usually the rubbers on the body of the car itself that clap out maybe inspect them for wear??
Posted: Thu Jun 01, 2006 10:59 pm
and that sort of breeze that mysteriously rips across my Brumby is probably very similar. I never worry about it until winter though, funny that !
Posted: Fri Jun 02, 2006 7:59 am
by vincentvega
all gen1 libs have wind noise problems.
search http://www.rslibertyclub.org for solutions. theres plenty of info there
i just ignore mine
Posted: Fri Jun 02, 2006 9:15 am
by subelover
hi yep wind the window down and grab the triangle support behind the mirror and give it a tweak worked well on my liberty no wind noise anymore cheers
Posted: Fri Jun 02, 2006 10:51 am
by Captain Obvious
yep grab the triangle and yank it in worked for me and my dad
Posted: Fri Jun 02, 2006 7:20 pm
by subarursliberty
I've had it for 4.5 years now. tried everything. I just don't care anymore the exhaust drones it out. :lol:
Posted: Sat Jun 03, 2006 9:14 pm
by AlpineRaven
I dont know if its true that it'll fix it, I cannot hear high pitched sounds including whistles.. so from what I heard, get some electrical tape, tape around where the gap where which it enables you to retract the mirror towards the car. You won't be able to pull in the mirrors in once it taped up the gap - If you dont understand, i'll grab a picture for ya.
Gen 2 & 3 liberty has the same problem.
Posted: Wed Feb 06, 2008 5:08 pm
by Bumpty
I love thread mining... I'm off to try some of your solutions as well...
Posted: Wed Feb 06, 2008 7:54 pm
by coops
When i did my mechanic apprenticeship at a subaru dealership at the time of the release of the series 1 libery we had problems right from the start with wind noise around the mirrors. Subarus fix was to put the wind down, open the door and apply a large upward pressure to the mirror. You will be basiclly bending the panel the the mirror is mounted to. We thought it was a bit rough then but it worked.
Posted: Thu Feb 07, 2008 11:18 am
by SUBYDAZZ
I fixed mine just after I got it, you can take the door and window trim off and adjust the rollers and limits for the window. Seemed to work for me, it takes a bit of playing but works. Also, that triangle thing can do with a little squeezing sometimes. Also check the door is closing flush to the body, may need to adjust the striker / lock. Only issues I have (if you can call it one) is that the window tends to rattle a little on rough roads if not completely up or down.
Posted: Thu Feb 07, 2008 11:43 am
by FROG
coops wrote:When i did my mechanic apprenticeship at a subaru dealership at the time of the release of the series 1 libery we had problems right from the start with wind noise around the mirrors. Subarus fix was to put the wind down, open the door and apply a large upward pressure to the mirror. You will be basiclly bending the panel the the mirror is mounted to. We thought it was a bit rough then but it worked.
we still do that :rolleyes::D:rolleyes:
