Page 1 of 2
Most subie engine Nm and kW in here now
Posted: Wed Jun 14, 2006 2:37 pm
I have renewed faith in EA82T after comparing TORQUE figures found in tune up spec book (could be errors)
EJ 22 16 valve 89 - 95 models
100 KW @ 6500
189Nm @ 4800
EJ 16 93 - 95 models
66KW @ 5600
128Nm @ 4000
EA81 79 - 84
4WD 9.2:1 comp ratio 59 kW @ 5200
135Nm @ 2400
FWD 9.0:1 comp ratio 60kW @ 5200
135Nm @ 2400
EJ 18 S
76KW @ 5600
147Nm @ 4400
EA82 carby
77KW @ 6000
142Nm TORQUE @ 4800
EA82 T
83KW @ 4800
181Nm TORQUE @ 2800
EJ20 DOHC 16 valves
85kW @5600
170Nm @4400
EJ20 E SOHC
92kW @ 5600
184Nm @ 3600
EJ20G DOHC Turbo
160kW @ 5600
290Nm @ 4000
EJ25D SOHC
115kW @ 5600
223Nm @ 3600
EJ25 DOHC 16 valve
115kW @ 5600 !
221Nm @ 4000 !
COMPARE LITRE TO LITRE between EA & EJ, not a noticeable torque increase between normal aspiration. KW yeah, but who drives at 6000 rpm (other than Tim)
until I experience reliability problems with 20 year old design I can't or won't comment
can see why EJ22 is nice choice as comparable to EA82T. In NSW EJ20 should comply with owner modified rego rules and no certificate from engineer needed ?
uh oh, what is this gonna start ?
Posted: Wed Jun 14, 2006 2:41 pm
by Suba
The EJ 18 and the ea82 comparisons surprise me , I would have thought that the ej18 would have been much higher than the ea82 , I know mine used to beat Lseries and I had 27'' tyres on
Mike.[/url]
Posted: Wed Jun 14, 2006 4:57 pm
by PeeJay
Those EA82Ts do have good torque, they seem to just purr up big hills in 5th.
Posted: Wed Jun 14, 2006 7:45 pm
by Bratgeebah
Anything on ej25's jono? (single cam not turbo)
Gee
Posted: Wed Jun 14, 2006 7:52 pm
by simmo
i'd love to see some EJ20 specs.....
Posted: Wed Jun 14, 2006 8:08 pm
by Suba
EJ20-R DOHC 16V NA, AVCS
190ps/7100rpm 20kg.m/4400rpm
EJ20-i SOHC 16V NA (the first ULEV Subaru motor)
140ps/5600rpm 19kg.m/4400rpm
Mike.
Posted: Wed Jun 14, 2006 8:09 pm
by Suby Wan Kenobi
The EA engine isnt a 20 year old design it dates back to the late sixties, i like the figures but an easy gain in the EA82T is to add more boost (please renew headgaskets if you dont know how long they have been there, i get fed up with the bashers saying they are a shit motor because of failure of 20year old head gaskets and a healthy dose of boost) at 10psi you will get around 100kw and if you go to 12-14psi you will gain more and it will still be reliable, not to mention the added torque.
Posted: Wed Jun 14, 2006 8:28 pm
by simmo
thanks suba
Posted: Wed Jun 14, 2006 11:05 pm
different rulers being used here kg/ metre ?
have to do at least head gaskets, can't even drive without pumping most water out of it in minutes ! oil leaks too so new gaskets and seals everywhere ...
Posted: Fri Jun 16, 2006 7:23 pm
by Gannon
i thought the ea82 carby was only about 66kw /85hp, ea82mpfi is about 90hp (vortex mpfi 90hp)
This could be a very interesting thread
Posted: Fri Jun 16, 2006 7:39 pm
by tim_81coupe
There is no way that a carby EA82 has more power than an EJ18.
I thought the carby models were rated at 60kw, and the MPFI ones at 75kw?
The EA82 I have in my wagon now doesn't have that much more than the old EA81 did, and that EA81 had no compression! Plus my EA82 has a Weber.
Carby EA82 heads flow about the same amount as a head off a postie bike. There's no way a carby EA82 has anything on an EJ18.
Posted: Fri Jun 16, 2006 9:51 pm
by Chris_Rogers
Suba wrote:EJ20-R DOHC 16V NA, AVCS
Mike.
EJ20R - is this the one I have? (BG5 Legacy GTB TT)
Posted: Sat Jun 17, 2006 11:12 am
by Ben
My L with Ej20 drives like a stock turbo ea. EA's are shit motors because of the cooling capacity, Dave is right though, anyone who calls them for shit because they failed headgaskets after upping the boost is a dick.
EA82's on 11psi, intercooled and 2.5" exhasut are a brilliant little package.
Only prob here is I need a cert to fit an ea82t, none to fit an EJ20 I know which is easier in the long run...
Posted: Sat Jun 17, 2006 1:18 pm
cooling capacity of motor itself or its stock radiators ?
Posted: Sun Jun 18, 2006 6:42 pm
by Ben
jono wrote:cooling capacity of motor itself or its stock radiators ?
Water flows through the heads too quick, take a look in the heads, coolant channels may as well not be there :P
Posted: Mon Jun 19, 2006 8:36 pm
so has anyone tried to modify the flow rate to reduce it perhaps and what do you reckon could be/should be done (other than fit an EJxx ) ?
Posted: Mon Jun 19, 2006 8:56 pm
Some of these figures seem to cause some concern, that maybe they are not correct (they are listed as DIN ?) must look to see what they credit the EA81 in the older versions some time
Posted: Mon Jun 19, 2006 9:27 pm
has any1 picked the twin cam EJ20 got less figures than the SOHC ?
don't look at me ...until I check my sources
Posted: Mon Jun 19, 2006 9:41 pm
by wildhorse
this is just the start. next you might consider driveline drag betwen each...ie... readouts at the wheels.
Posted: Tue Jun 20, 2006 7:49 am
by joe_ritson
Hey wildhorse, did you use XT6 hubs/custom drilled hubs/EJ driveline for those rims?
