Lift Kit steering extension
Posted: Tue Nov 15, 2005 5:36 pm
by subius
G'day all,
I recently bought a second hand lift kit for an L wagon but i soon discovered it didn't come with a steering extension. So my standard steering arm is currently just holding on with about 2mm either end. Very dodgy
So i need to find one fast as this is the car i drive everyday.
Any info would be great.
Posted: Tue Nov 15, 2005 6:08 pm
by xaymaca
Only telling what I've heard but maybe try an Outback steering arm? Don't ask me what year or anything, maybe see if a workshop has heard of doing this before?
Posted: Tue Nov 15, 2005 6:48 pm
by Ben
Give Scorpion a call, ~$110 for a splined extension to suit 2" kits and are 100% completely legal in all states.
http://www.scorpionsubaru.com/
Posted: Tue Nov 15, 2005 8:33 pm
by bluesteel
just cut the one you have and get a bit welded in the middle... i know u have a spare... will cost you like 50 bucks tops
Posted: Tue Nov 15, 2005 9:17 pm
by SuBaRiNo
Im running a spline extension but i sure wish i had of got mine welded. I say weld it.
Dave
Posted: Tue Nov 15, 2005 9:31 pm
by subius
Thanks for that. Sent scorpion an email, will check out the Outbacks too.
If i get a block welded in the middle, is that going to stuff up the angles on the universal joint? Cos the spline is the bit that needs extending not the middle bit right?
Posted: Tue Nov 15, 2005 9:34 pm
by SuBaRiNo
Actually... important question... do u have Power Steering?
Dave
Posted: Tue Nov 15, 2005 9:37 pm
by subius
nope. The car i got the lift of had power steering which is why it doesn't fit mine.
Posted: Wed Nov 16, 2005 7:25 am
by vincentvega
SuBaRiNo wrote:Im running a spline extension but i sure wish i had of got mine welded. I say weld it.
Dave
why?
I have a welded extension, and i wish i had a splined one
Welding an extension in the middle of the joint means the top uni joint is on a huge angle. It works but i dont like the look of it.
Extending the spline gives you pretty much stock angles o nteh unis, and is legal...
