Calling all KIWI members....
Loyale 2.7 Turbo
Post by Loyale 2.7 Turbo » Thu Oct 13, 2011 7:06 am
Also this one:
Loyale 2.7 Turbo
Post by Loyale 2.7 Turbo » Sat Dec 03, 2011 2:58 am
subaruby wrote:Dont know anything about it but found some old pics on my computer
I Just came across This engine, found in a First-Gen Subaru Brat (Brumby):
Could it has the same setup as the one on the Picture above?
AUSUBARU MASTER
Post by steptoe » Sat Dec 03, 2011 9:36 pm
Wow ! Isn't that some good find, great piece of fabrication on an EA71?
Noticed the thermostat housing at the top and manifold looks to be hacked off at the ends to keep water circulation job
Must have been a screamer in its day :)
Post by Silverbullet » Sat Dec 03, 2011 9:48 pm
Loyale 2.7 Turbo wrote:
When I saw this I thought "No, it couldn't possibly be..."
Then read Jonno's post about EA71 and fabrication and realized what was going on :rolleyes: Very very interesting that someone would go to all this trouble, I wonder how it turned out. Seeing how they drilled big holes in each head and welded those manifolds on, makes a DIY quad carb EA81 seem a lot more do-able...no no no what am I thinking, shouldn't be getting ideas :mrgreen:
AUSUBARU ELDER
Post by TOONGA » Sat Dec 03, 2011 11:57 pm
If one was crazy enough, they could weld the supports for an EJ manifold onto an EA81 then run it with a turbo and injection.
at least until it went pop :) but Im sure it would be fun up until that point :)
Loyale 2.7 Turbo
Post by Loyale 2.7 Turbo » Mon Jun 25, 2012 11:47 pm
Yes, it is an EA71, but I was thinking about the Single Port that the Standard and the Fat-Case EA71's Heads does have, and this thing looks like it has Two.
Well, in another note; There is one Second Gen Subaru Leone RX coupe with one of those EA81S Engines (with Four port Heads and Twin Downdraft Weber Carbs, each one directly bolted to the Head) from the Safari Rally, is Now For Sale in New Zealand!!!
Follow this Link, ~► Here:
http://www.trademe.co.nz/motors/used-ca ... 634699.htm
Kind Regards.
AUSUBARU MASTER
Post by steptoe » Tue Jun 26, 2012 8:45 am
not just the heads, it is a whole car for a bit more than 10,000 NZ $ !
nncoolg
Turbo Talker
Post by nncoolg » Tue Jun 26, 2012 6:21 pm
Not a bad piece of gear, of course for 10k you could buy a few sets of Sub4 heads...
# EA82 AWD 4EAT,
AUSUBARU MASTER
Post by steptoe » Tue Jun 26, 2012 7:31 pm
bet Tweety goes harder ....
Loyale 2.7 Turbo
Post by Loyale 2.7 Turbo » Thu Dec 20, 2012 2:49 pm
Well... that EA81S engined Subaru RX Coupe is still for Sale, I Wish I could buy it, but it is So far from me...
AUSUBARU MASTER
Post by steptoe » Tue Jun 19, 2018 10:51 am
BUMP.. bet facebook not got this stuff contained in here !!
