Engine boost at what rpm?
Similar to steptoe's thread below on engine rpm at a certain speed, I was wondering at what revs people are getting full boost running an EA82t?
I have stock boost levels with only mod a 2.5" exhaust all the way and I get a full indicated 8psi at between 2000-2100rpm.
Others?
Others?
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
2004 Outback H6
2004 Forester XS
Yeah that sounds about right, only mines only at 6.5 psi
I would check the accuracy of your boost gauge.
At 2000RPM it should be just coming on to boost. I.e. 1 to 5 PSI
I am pulling a full 11.5 PSI @ 2000RPM due to my redesigned 'Up' pipe....
http://www.subiparts.com.au
0438 887 746
0438 887 746
ahhaha dam matatak!
Hunter S. Thompson
Hunter S. Thompson
I will PM you later about it I have just been tied up with work & personal commitments....
0438 887 746
0438 887 746
I cant see the problem with that, at about 1900 the needle nudges just past 0psi and by about 2200 there is the desired 6.5psiXtreme_RX wrote:I would check the accuracy of your boost gauge.
11psi at 2k, so at what point do you start building boost? (please say idle;))
One of these redesigned uppipes might be worth a go
- Suby Wan Kenobi
It rolls past the 0PSI mark at about 1700RPmSuparoo wrote:I cant see the problem with that, at about 1900 the needle nudges just past 0psi and by about 2200 there is the desired 6.5psi
0438 887 746
0438 887 746
Cool
I havent even see a pic of this super up pipe, have any been posted yet?
4-5PSI @ 2000RPM is with the boost tap closed (max boost 7PSI)
11.5PSI @ 2000RPM is with the boost top open
(Unrestricted waste gate action till 11.5PSI)
Big difference between 'factory' & 'Open'
0438 887 746
0438 887 746
