D3V1L wrote:tasers...in the drivers seats
....cousin did it in adelaide.....tested on a mate...fried him!!!! never talked to each other again so i dare say it will work
dave
There is a simple DIY setup an auto sparky mate told me to do, with the same effect:;)
Get an old Ignition coil, HT lead and a relay, and some wire and connectors.
Wire the relay contacts through its own coil (so that the relay will pull in, then drops out - chatters) to power the Ignition coil.
Plug in the HT lead into the coil and bear back the end so that the carbon end has a nice exposed length on it.
Run the HT lead between the back of the seat base (so that the lead is sat on)
Run the power off the ignition circuit, and a return to ground.
When the ignition is cranked, the coil will whack the bastard with 30,000V up the arse.
Fit a hidden override switch in there too, so you dont cop it.
Oh by all means go ahead with a mod to stop the car from running also.
My mate did this to an old car up a Mt Newman, one night he woke to the screams of someone trying to take his car - worked good hey!:mrgreen:
